comes with everything you need. except motor. motor is around $500-600.
i assume the little white piece has broken so the cable wont stay where its meant to, or is it all useless ?
i dont have a part number but your friendly local nissan dealer will know what your talking about, just the regulator assembly for the particular door approx a 6day turn around from japan. the last time i broke one and ordered it anyway lol.
otherwise i would try nisswreck. im a regular visitor to upgarage in sydney and i know they have a few ceffy doors. not sure if its all intact.
upgarage.com.au
Call Ric , give him a call on monday and say Mick, the good looking kiwi sent you
or i can have a look this coming friday.
Edited by esky_mad
https://www.sau.com.au/forums/topic/211155-sorted/#findComment-3739432
wally @ z imports has a set of cefiro doors in stock - not sure what exactly they have on them, still had trims on
part number: 80721-71L05- REGULATOR ASSY-DOOR WINDOW,LH
or if that ones no good - 80721-71L15-
Edited by TonyL
https://www.sau.com.au/forums/topic/211155-sorted/#findComment-3770447
I just scored a passenger side door complete to replace my dented door, which was working complete. If you haven't already organised a solution I could strip my door for parts and post them to you? PM me if you are interested.
Edited by daisu
https://www.sau.com.au/forums/topic/211155-sorted/#findComment-3786232
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
