comes with everything you need. except motor. motor is around $500-600.
i assume the little white piece has broken so the cable wont stay where its meant to, or is it all useless ?
i dont have a part number but your friendly local nissan dealer will know what your talking about, just the regulator assembly for the particular door approx a 6day turn around from japan. the last time i broke one and ordered it anyway lol.
otherwise i would try nisswreck. im a regular visitor to upgarage in sydney and i know they have a few ceffy doors. not sure if its all intact.
upgarage.com.au
Call Ric , give him a call on monday and say Mick, the good looking kiwi sent you
or i can have a look this coming friday.
Edited by esky_mad
https://www.sau.com.au/forums/topic/211155-sorted/#findComment-3739432
wally @ z imports has a set of cefiro doors in stock - not sure what exactly they have on them, still had trims on
part number: 80721-71L05- REGULATOR ASSY-DOOR WINDOW,LH
or if that ones no good - 80721-71L15-
Edited by TonyL
https://www.sau.com.au/forums/topic/211155-sorted/#findComment-3770447
I just scored a passenger side door complete to replace my dented door, which was working complete. If you haven't already organised a solution I could strip my door for parts and post them to you? PM me if you are interested.
Edited by daisu
https://www.sau.com.au/forums/topic/211155-sorted/#findComment-3786232
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
