my r33 gtst has blown another bush bearing hiflowed turbo. only 3000k's old. never been boosted past 14 psi.
the comp wheel has disentergrated but no shaft play and rear wheel in tact. still spins perfect. and nothing has gone through the turbo as the afm and panel filter are still in perfect order.
the last turbo that had failed was due to apparent oil contamination but i done an engine oil flush, new filters, and braided oil lines. so i dont think there was a chance of that happening again. made damn sure of it but this new one has gone on me. so upsetting. i was told it would be perfect and up to spec and should be fine for 18psi if i wanted to boost the turbo more at a later date.
i hope the 12 month warranty will cover this.
as i am in the hunt for a new turbo setup,( ball bearing this time ) what would best suit me to reach a goal of 260-270 rwk on say 15 psi that is a direct bolt on application for my r33 gtst.
thankyou.
https://www.sau.com.au/forums/topic/211171-another-blown-hiflow/
i think the cause of the turbo dying was too much preload off the actuator???
i never had a boost controller. had to boost the car like this.
another tuner i took it to said whoever tuned your car has put too much preload on the actuator.
Too much preload wont kill a turbo unless it cant handle the boost you are running (which is so unlikely its not funny) :down:
So whoever was feeding you that - is full of shit :(
More pre-load the better if your running higher boost levels. Leads to less chance of boost spikes and creeps.
looking at a garrett 3071r turbo... will it make about 260-270rwk without ringing its neck. i dont know much about specs so if someone could reccommend a turbo for me for that power running about 15-16psi would be much appreciated
this time im gonna do it right
You run a BOV as opposed to a so called 'dose' pipe or none at all?
i run the standard BOV. the bov is slightly squashed to incerase spring tension ( was told to do this on the forums).
was getting compressor surge still. not huge amount though
There's nothing inherently wrong with a bushed turbo. You don't see 15 year old s13's spitting out compressors every 10k.
My last turbo was bushed and that copped a flogging for 2 years that i owned it without missing a beat. It wasn't water cooled either. Hopefully the new owner gets plenty of enjoyment out of it too.
I can't really add any more at this stage other than you are either very unlucky, or you have missed something on both your installs. You don't still have the stock banjo at the block end or something like that? Have you tried cranking the engine with the oil feed off and see if it is getting oil through?
There's nothing wrong with a k&n panel. I run one myself as do numerous other members. What sort of intake pipe do you run? is there evidence of paint/chrome/rust flakes on the inside?
The 3071 seems to be the turbo of the moment. I have a few teething problems atm so i'm not going to say it will or won't meet your expectations, but an initial lazy run of 260rwkw on 16psi looks promising, as does the boost response if you can keep the gate closed. I just have to work through a boost control issue at the moment which i strongly suspect is dump pipe related and hopefully it will be good.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
