as said i got redline shockproof lightweight put in my 32GTR gearbox today and i had bought 1 gallon = 3.75 litres or whatever it is, and it wasnt enough it still needs almost another litre... whats the go? i read on here from loads of other people that 1 gallon would be more then enough?
any help would be great
Cheers,
Corey
1 gallon is 4.5L
as long as the car is level, all you need to do is keep filling it 'till it starts to come out of the plug hole. just add normal g.b oil if ur out of Redline- it blends anyway
1 gallon is 4.5L
Wrong.. I gallon is 3.78litres
check google...
Who's gallon? The Seppos have a different (lesser) amount in their gallons than the empire does.
1 US gallon equals 3.785 litres.
1 Imperial gallon equals 4.546 litres.
well seeing as we are talking about Redline.. which is a US product... and the fact that it states 3.78litres on the bottle... im going with 3.78
Cheers,
Corey
There really is no set amount seeing as how you may have been empty when filling anything I always grab more then needed. You just fill till it seeps out then you know your good...
I just did all my fluids too.. 2 bottles of royal purple in each diff, and 2 bottles of Automatic Transmission Fluid in the transfer case as reccomended by Nissan... Shifts smoother then ever...
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
