as said i got redline shockproof lightweight put in my 32GTR gearbox today and i had bought 1 gallon = 3.75 litres or whatever it is, and it wasnt enough it still needs almost another litre... whats the go? i read on here from loads of other people that 1 gallon would be more then enough?
any help would be great
Cheers,
Corey
1 gallon is 4.5L
as long as the car is level, all you need to do is keep filling it 'till it starts to come out of the plug hole. just add normal g.b oil if ur out of Redline- it blends anyway
1 gallon is 4.5L
Wrong.. I gallon is 3.78litres
check google...
Who's gallon? The Seppos have a different (lesser) amount in their gallons than the empire does.
1 US gallon equals 3.785 litres.
1 Imperial gallon equals 4.546 litres.
well seeing as we are talking about Redline.. which is a US product... and the fact that it states 3.78litres on the bottle... im going with 3.78
Cheers,
Corey
There really is no set amount seeing as how you may have been empty when filling anything I always grab more then needed. You just fill till it seeps out then you know your good...
I just did all my fluids too.. 2 bottles of royal purple in each diff, and 2 bottles of Automatic Transmission Fluid in the transfer case as reccomended by Nissan... Shifts smoother then ever...
    • I’m going Barra fishing with my mate this weekend coming so I could probably stop in at yours on the way back home maybe Sunday arvo or Monday morning.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
