hey guys, i have an exedy hd cushioned button clutch which i got installed not too long ago. i also got the flywheel machined and a new thrust bearing.
the car's been alright for a while, and the clutch feels normal, but over the last couple weeks it's started to hiss at friction point (when the clutch touches the flywheel).
the clutch doesn't slip, or drive any different to when i got it installed. it drives the exact same.
what i did notice though is that it does shudder when i take off in 1st gear. i always thought it was because the clutch grabs really fast/well.
my mechanic says i've glazed my clutch or flywheel, but i don't ride on the clutch like an L plater would driving a manual car.
i was told that it would wear away after a while but it hasn't. the hiss is quite loud if you're standing outside the car.
what should i do in this situation? is my only option to get the flywheel re-machined?
your opinions...
https://www.sau.com.au/forums/topic/211179-glazed-clutch-need-helpopinions/
All my clutches have hissed just as they start to engage. Even the old organic. :cheers:
Its normal.
My exedy 4puk solid button shudders less then the old xtreme 9puk.
Button = shudder if you try to ride them.
If you do ride them say good bye to it within 20,000km's.
I got 70,000km's out of my last ceramic 9puk but i would pop it when ever i could; avoid riding it.
All my clutches have hissed just as they start to engage. Even the old organic. :action-smiley-069:
Its normal.
thanks for all the replies guys. :D
thing is though Cubes, it never used to hiss up until not long ago. this is what i'm curious about, as it doesn't feel like it should be happening.
my clutch whines like a dying whale when I ride it to move around carparks and stuff...
starting making this noise when I let my friend borrow my car.. anyone got ideas as well?
Its a Unique Autosports Cushion Button clutch...
I could have the same problem as dmr
there's a big difference between a little hiss and a whine.. i know mine is hissing because of smooth metal contact, but yours could be something else. does it slip?
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
