Item:R33 RB25 engine, series 1
Age: 130,000kms
Condition: Engine was blowing a fair amount of smoke, was compression tested by workshop and the result was, 6th piston had very very low compression but all the others were fine, his diagnosis for the 6th piston is more than likely ringlands.
Price:$$NOT SURE... Whatever your willing to pay
To Fit: R33 Skyline
Contact: Contact via PM
Comments:
mate i sold my head for $300 and a couple of the other bits, made about $600 so far. youll be doing well to find a buyer for the block. unless someone wants to rebuild one for a high performance application, but even then youd get $100 tops.
Whats your location, interested depending on frieght costs. Any auxilarys included?
The location of the engine is Tuggerah, on the central coast of NSW. It is currently still at the workshop and can be picked up or freighted from there.. They obviously have an engine crane, so all you would need is to bring along a trailor or a ute or something. It has pretty much everything, just as stated above.. When you say auxilarys what specifically did you mean for example??
Inlet manifold, plenum, injectors, starter, alternator etc.
  • 1 month later...
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
