  • Replies 46
thats a very interesting theory. a bit far fetched perhaps, i see no reason why my car would be an auto convert! are there any cosmetic giveaways?
im very interested to hear your results.
hi,
got the car back on saturday, alot later then i expected, but thats always the case with machanics :wave:
now running standard R33 GTST manual box with Auto diff
i didnt get to test a large rev range as i didnt drive on the motor way over the weekend
however i did get the chance to do:
40kmh at 1000rpm and
80kmh at 2000rpm
id like to test 3000rpm but it does look like it will be 120kmh
agreed the theory was a bit far fetched :bunny: so mayby someone replaced the manual diff with an auto for high speeds
agreed the theory was a bit far fetched ;) so mayby someone replaced the manual diff with an auto for high speeds
how bizarre. thanks for your input! i think i may replace the diff down the track, but i guess having taller ratio would be good for highway, but standard ratio would be better for acceleration. im still not convinced my car is abnormal though lol. maybe the speedo is just out a bit haha.
There is a "rolling road" dyno that measures km/h. But is for checking speedo accuracy.
They put a device on the dash which displays speed at the wheels
and compare to speedo speed.
I had my car tested on this dyno. Goes up to 180km/h on the certificate of accuracy.
Edited by SKYPER
  • 1 month later...
It IS a bit out... at those speeds, definitely. It's a mechanical speedo, and its definitely not meant to be accurate over its 180km/h limit.
My mrs has a series 1 r31 N/A rb30 auto it sits on 2500 rpm at 100km/h but it goes hard of the line so i did some checking the auto came out with a 4.44 diff centre compared to 3.9/4.11 for the manual. So on take off the auto is comparable to a manual but once you get high in the rev range the auto cannot pull back the manual becuase the manual has the lower diff ratio it can pull more km per rpm. Look to the salt lake racers all of them would be running 2.7 diff ratios but it takes them 1.6 km to get up to speed. Rod hadfiled has built a commodore that does over 400km/h it is a salt lake racer has huge hp but its all in the diff ratio rear box ratio and try diameter.
http://www.1010tires.com/TireSizeCalculato...p?action=submit
This is a handy app to use the above to calculate your tyre diameter then fill in the rest this is obviously not concrete but rough guide if you play with it you see the differences in diff ratio and try size play in top speed
http://www.dennysdriveshaft.com/html/poten...calculator.html
Gear ratios can be found here
http://carizma.com.au/Pages/Details%20-%20...e%20-%20R33.htm
Edited by AndyD
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
