Just been informed they have GT2860R-7's restrictors built in.
Guy also said a lot of people actually remove the restrictors thinking they are improving flow - apparently the shaft is actually physically supported by the internal restrictor and then go boom. Bogans and turbos don't mix. :D
Sorry to Hijack the thread, but Ive done a bit of reading on this and apparently all the GT series of Garrett's have restrictors built in.
Now I'm not sure if we should believe this, it seems as though half the people out there say to use restrictors and half the people say they are built in.
I'm about to fit a set of GT2560Rs (707160 - 9, the GT-SS equivalents) to an R32 GTR and I'm in the same boat you were, not sure whether to just bolt them up, or to put restrictors in.
The sticker on the plastic wrap the turbos come in say not to exceed 60psi which leads me to think the restrictors are not built in. Also, in the GT-SS kit (which I didn't get) they have a banjo restrictor to put in place.
Can someone with a bit a bit of knowledge please help clarify this???
I know the turbos will work without the restrictors, but will this put exessive loading on the seals and blow them out 10,000Kms down the line? or are there internal restrictors?
No not at all - thats the kind of info I am after.
Definitely odd that it would have that warning if there was a restrictor built in. We were assured they have a restrictor - mate who picked them up said the guy showed him another turbo without a restrictor to compare.
Do not use a oil restrictor if you have one built into the turbo.
I have heard this can cause back pressure on the oil lines.
If you still want to restrict some flow......have a smaller diameter oil line made up.
IE..take your line to H.I.S. Hose and ask them to make you another line using your
connectors.
Very good Idea TiTAN, I'll call GCG on Tuesday to confirm and see if I can find out which turbos do actually have a restrictor in them, unless someone has already done this???
Looking at the oil feed hole for the GT-SS's there doesn't seem to be anything restricting there (like a mushroom looking thing that others have mentioned) it just goes into what looks like a chamber or pocket.
Is that the case with yours to paulR32gtr? or were you told that the restrictors were actually inside the turbo and not visible?
In my research, often the Garrett's come with a 1.2mm restrictor in place. However, there is a 0.8mm restrictor available from Garrett. I didn't check mine before installing, but I believe I have the 1.2mm in place.. I am also getting some oil past the turbo seals...
From what I have learned/read/asked - I would be fitting the 0.8mm restrictors from Garrett if i were you.. since they are ball bearing, you only need a good quality oil getting through there to lube them, you don't need the kind of pressure that a journal bearing requires...
Not what you want!
We are putting the turbos on tomorrow so ill compare against the stockies.
HKS GT-SS's are on the way for my car and I am going to trust their kit - guess if they are including restrictors for what are essentially a GT2860R-9 frame with all the same CHRA physical characteristics as the -7's - we should be doing something about it.
Ok, I called GCG and emailed them so I got responses from 2 different people just to be sure.
They were both very helpful and both stated that there were inbuilt restrictors so additional ones were not necessary to install on an R32 GTR in the GT2860 range.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
