I am wanting to upgrade my ecu soon, but have been quoted around 2200 + for supply install tune. What does a install tune usely cost on dyno etc?
I thought about buying else where and getting it tuned here. Cause the aus dollar is pretty good and apexi usa which is not bankrupt still sells them. I think they might even sell an updated one. What do you think about this link below
http://www.directtuning.com/store/pc-67102-62-apexi-power-fc-w-commander-skyline-93-98-ecr33rb25det.aspx
that works out to about 966 aus dollars what do you think?
https://www.sau.com.au/forums/topic/211233-apexi-power-fc-rb25det/
I'd be very surprised if they still have them in stock at that price, most likely they haven't updated their website as these are going for $1500 second hand.
If they say they do have them, be very careful that it's not a scam.
PRODUCT
A'PEXi POWER FC W/ COMMANDER: SKYLINE 93-98 (ECR33/RB25DET) APX-414AN012 $882.00
Quantity: 35
To remove an item, click Delete next to its quantity
To update pricing after changing quantities, click Update Prices
To place your order, click Checkout
Enter any special offer/discount coupon code here: Subtotal: $30,870.00
Tax: $0.00
Shipping Method: $0.00
Total: $30,870.00
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
