Rb 26 Into A R32 Gts-t Worth It?
335
 Share
Hello
I was wondering if its worth putting a RB 26DETT into a R32 GTS-T? What are the good points and bad points?
I found a engine so wanted to know before I started mod my RB20
Thanks
Help
  • Replies 49
Hello
Thanks
Help
you ever seen the GTST 2GU UP?? Thats got an RB26/30 in it..that shows its worth it..its just whether you wanna spend the money
Hey man,
From what i read on here, looking at Shaun's gorgeous white R32 with a 26 in it and others, RB25 will make the power you need. When you need more power then one can make, your getting to the point where you cant put it down properally.
Try and grab Shaun's ear for a chat bout it :D
Hello
Thanks
Help
Nope, not worth it IMO
It depends how deep your pockets are!
I was in a situation where i had imported a late model R32 gtst that was in awesome condition, and i had reached the upper limits of power for the RB20. A 25 wasnt a huge step up, so i decided on the 26. Also, the 26 is more appealing to the eye than a 20/25 in my opinion.
If i had my time over again, i would probably just by an R32 gtr and develop that; but when i started, r32 gtr's were still above $32000, and i couldnt afford that.
If its gonna be a daily driver, i dont believe the massive outlay in money is worth it. Id probably capitalise on someone elses loss and buy a modified gtr, and then add your finishing touches.
Thanks for the kind words GeeTR!
PS i passed my engineering inspection today, so now i can register my car (another headache with an RB26 into a gtst!)
Shaun.
Depends what your budget is, how much you can do yourself? If any? What do you want to use the car for and what are your power goals?
I’m a firm believer it’s a worthy conversion if you don’t have to pay someone. The initial outlay for an rb26 may out weigh the cost of throwing in a mild rb25 for example.
Have you thought about trying to find a Gtst with an rb26 already in it? My mate picked up R32 with a built/forged rb26, motec ecu ect makes 420rwhp on 11psi for $18k!
I sold my R32 gtst with an rb25 stroker motor and trust gearbox for $22k, recently made 730hp at the flywheel on an engine dyno.
Bargains are out there if you look.. Cash in on someone else’s money pit
No.......not worth it at all...
Unless you have a micky mouse 32...and I mean $5K paint, custom interior, gauges etc etc.
If I were you.....get a GTR32....at least your less likely to wrap yourself around a pole.
^^^^^ What does that mean??
As a paramedic, ive seen plenty of gtr's wrapped around poles; such as the blue R34 gtr in which three were killed a few years ago on the central coast. Obviously, its how you drive it.
I agree that you've got to figure out what you want to achieve with the car, and if your going to keep it, because you'll never get your money back.
But at the price of r32 gtr's atm, you'd be hard pressed not to buy one and modify it. Your gtst with 26 will never be a gtr. Hence, when R34 gtr's hit $30k im gettin one!
Shaun.
As with all of the above it totally depends on what you want to do with the car. But if you're looking to put that power down in a straight line forget it - unless you've got some serious tread on the back. I drove my GTR for a week with the 4wd fuse pulled and under full power is a masive handful, the torque is out of control! And that's a in car they weighs quite a bit more than a GTS-T.
Now I know there's sh!tloads of cars out there with umpteen power and only 2WD but IMO having the traction just makes it more useable - unless of course you just want to drift the thing.
I may have been incorrectly informed but cant you swap the RB26 Tappet cover/cam pulley covers onto an RB25? If you have a front facing plenum that is? havnt seen it, but have been told so correct me if need be.
This way you have a more visually appealing RB25 than your average RB25 :thumbsup:
Shaun.
I stated less likely... :D
If you want to go around a corner at 100ks' an hour. :rofl: .
I know which car I would prefer to be in for safety.
By all means I am not in couraging dangerous driving.
Why would you need 400RWKW's in a R32 anyway........blow your tyres up with maybe :D
Hello
Thanks
Help
Mod your RB20......but don't spend to much money on it.
Buy second hand parts and just enjoy the drive.
If your looking for a faster car...get a faster car.
That is all.
the only reason that ones worth it is because its a 3L....not because its got a 26 in it
That is all.
Why do people put down the 32? I think the body style is much better than the 33. If I could afford a R34 gtt, I would buy that. I like the handling of the 32. I know with the mods I am going to do I will get 300 hp but I wanted to check with the RB26 because if it is possible, I would put that in. I think the body and set up of the 32 is fine especially compared to other cars. I would rather have a 32 than a Subaru or Mitsubishi. I drove a R33 gts-t and that is too big and ugly for me. I feel these(32s) are already fast cars, maybe not the fastest but I think still in stock form not bad. I have thought of putting the RB25 in there but with the amount it would cost to properly put one in my car, I can mod my 20 for less.
Is it really worth it to put a RB25 in there? I heard somewhere that they are faster and have more torque in stock form but the RB20 is tougher and last longer. What does everyone think?
Edited by 335
If you have 15-20k you could get it built but like alot of people have already mentioned if you know what to avoid and you do relevant checks you may be able to buy a converted 32 already done by someone else and save a sh*tload.
big power 26 engines with killer top end at higher revs suit 4wd drivetrain IMO, im pretty biased on this but other setups rb25 or 30 with lower power but more torque are more usable on the street and cost less to buy. When you think about it the only time you'll get to put you foot down for more than 5 secs is going to be at a track in a controlled enviroment anyway.
26 in a 32gtst not worth it.
 Share
    • I have S15 helical too. It is a bit worn. I think the drive behaviour you describe is related to this wear. Wear of helicals is something that no-one seems to have paid a lot of attention to, but now that they (as in original Nissan ones) are all a bit old - we're starting to  see the consequences. The ends of the helical spurs wear into the casing. That's where they perform the braking that diverts torque. Some of the more modern helical designs have proper wear surfaces introduced there, but the Nissan ones are just steel on steel (or iron).
    • I've had a range of rear diff centres - open, viscous, helical, mechanical, welded, etc.   I can't go past a refreshed factory 32 gtr centre for consistent lock and street driving. The next step up for me would be the nismo 1.5 way , which likely suits you better as track sounds like the focus. Will chatter in carparks but its not the worst.   I have never tried a quaife rear diff, an option I've looked at before and might be one for you .....   Currently playing with an S15 centre at the moment and I hate it.  The transition from single wheel spin either side is just weird.
    • Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
    • I also run a CD009. I'm currently on a 4.08 and it's not great. I originally intended to run a 3.3 but had issues, more on that later. I'd stick to anywhere between a 3.3-3.7 as found in the 350z.  As for brands of ring and pinions, absolutely stay away from Speedtek. They are absolute garbage. See my build thread for more information on that. I went through two of there 3.3's and both had bad runout. They were paperweights and they have still yet to refund me.  I ended up putting in a Nissan 4.08, which was better then the original 4.36 but is far from ideal. I'm going to pop a 3.5 in this winter. I'd stick Nissan. I've also heard of a company "Neat Gearboxes" that makes them. Haven't tried them, but they can't be worst then Speedtek...
    • You should Nistune the ECU, so you have freedom to use modern injectors instead of replacing with the same old shit. This is also required if you want to boost it up above ~200rwkW, where the stock injectors will be running out of capacity. Having said that, it is unlikely that the injectors need replacing just 'coz. If you imported it from Japan, the fuel should have been pretty good quality for the whole life of the car.
