Rb 26 Into A R32 Gts-t Worth It?
335
 Share
If your after 224rwkw roughly i'd just rebuild the RB20 (if it's clapped out) and make it as reliable as possilbe. It can make that power without much stress. My mate is making 210rwkw in his R32 and his engine is dead stock with a decent turbo and support mods. If he rebuilt the motor (i told him to, as opposed to going an RB25 :D ) and got the head ported it would be seeing close to 250kw methinks and be tight, responsive and would last quite a while.
I reckon the extra CC's in the 25 and 26 make them better for the street because of the extra torque and generally quicker boost (depends on turbo size of course). I went on a crusie with three R32's recently and they don't make full boost till about 5000rpm. I easily pull away from them with my stock turbo RB25 until they're doing about 6500rpm and making FULL power :D .
So uprated cams and cam gears with a rebuild will help that, meaning all of this stuff done to your RB20 make it into a weapon.
So don't bother with the conversion if your not DETERMINED to go an RB26. Make what you have work.
  • Replies 49
fair statement with the extra cc's, but full boost at 5 grand? how big were the turbos they were running? would have to be something around the td06(10cm housing), gt30 range surely.
I know it's shocking lag. One dude had a KKR something and is about double the size of factory (it nearly touches the strut tower). Another had a highflow which was bored out to the point of the workshop saying "don't bolt it up too tight, you'll warp the housing" :cheers:
They go hard but RB20's need a bit of help if you put it up against the RB25+26. Cams and porting ftw.
Down low they do suffer. But i would like to add be careful with advice like head work and cams for helping RB20s. Unless of course you can site specific examples where it was worked. Personally from what i have done personally to my car and what other RB2o ownershave done....cams dont automatically do anything for an RB20. Certainly dont make them automatically responsive, certainly dont make them automatically allow them to make more power up top. As for porting, that can slow velocity at low rpm which hurts cylinder filling which will hurt gas velocity and turbo response.
So just be careful if posting absolutes as people can end up wasting lots of money.
The RB20 is a short stroke small discplacement 6 cylinder engine. It will never make great power down low. If you cant live with that then either sell the car or go transplant. If you dont mind waiting a tad for the power, or happy to drive around it...then they can deliver the sort of ols school power that makes you smile ear to ear :D Cheaply and reliably :D
tell em the price son, the price son.
Roy boys 250rwkw RB20 cost him $400 from the wreckers.
he then bolted his TD06, intercooler, injectors, PFC and a throat full of boost.
almost makes enough power to travel back in time to root his future mum.
Edited by GTST
The RB20 is a short stroke small discplacement 6 cylinder engine. It will never make great power down low. If you cant live with that then either sell the car or go transplant. If you dont mind waiting a tad for the power, or happy to drive around it...then they can deliver the sort of ols school power that makes you smile ear to ear :) Cheaply and reliably :banana:
What i say isn't absolute or expert opinion, it's my opinion. If anyone takes advice from someone on the forum and spends thousands without asking a workshop to verify are plain stupid :banana:
I agree that cams and porting don't gaurantee an awesome responsive motor. I'm talking from the perspective of RB20 Vs. RB26. If we're talking RB20 left stock to RB20 with head work then of course the stock with have better response but be more restrictive up top.
I can give an example of this work being done, and it backs up what you were saying. One of the dudes on the drive i went on had about 245rwkw on his RB20 with a pair of cams on the head. He said it made a big improvement. Another R32 had a totally stock engine but a slightly bigger turbo. Redlining third gear side-by-side the R32 with cams couldn't pull away (as you'd expect earlier power). Approaching redline the stock motor R32 began to edge away as the turbo on the cam'ed RB20 ran out of puff.
Saw that with my own eyes.
Either the guy was BSing about the amount of power he made or cams don't really do much unless the setup is real special ;)
So as i said, blow for blow a stock RB20 is a good thing for the street if you want response, versus a worked RB20 which might just gain lag from low RPM. But comparing it to an RB26 it will suffer BOTH down low and up top.
:P
Edited by R338OY
  • 3 months later...
 Share
    • I had the Blitz bonnet on my old boat and never had a issue with overheating anywhere Same car, but, after I sold it, weirdly I cannot find any pictures of it when I had it, maybe I deleted them all because they "triggered' me...LOL
    • I want someone to make side skirt extensions. But by 'extensions' I mean running from one side of the car to the other, forming a flat undertray, maybe one that runs to the front and rear of the car too
    • Meh, maybe the JSAI ones are FG not CF. But, given that I'm not convinced any of these look any good, it hardly matters.
    • Got them in the other day. I can confirm the r33/r34 nozzles (B8K30-AA000) are the exact same. Hope this helps anyone else that comes looking for it
    • Yeah, I should state I have no overheating issues except when it's sitting idle, with AC on (and only then) and only on VERY VERY hot days. And it stops if I turn the AC off. But I put a lot of effort into making this thing run like a regular car, I want the AC to work when I want it to work. I need no excuses as to why I should make some other thing a daily! And tbf, the thing does heat soak pretty bad, not much I can do with the exhaust running under the driver's seat, you can feel it through your shoes/pants when you step out of the car, too. Point being, aircon inside the cabin is on pretty frequently. I did think about removing heater hoses to simplify the engine bay/back of engine because I cannot imagine a scenario where I ever need a heater. Except for defogging, but doesn't AC do that, not the heater? So in this very limited situation, raising the rear could work, purely to let hot air out. I've ran the car at the track on a 35C day with the aircon on, and it doesn't overheat in that scenario so that's why I thought it was due to heat soak/heat buildup and not just general overheating under load. I had previously tried shrouding the radiator, changing my balancer to a non-underdriven one to spin the water pump more at idle too, and installing two more thermo fans on the other side of the radiator/AC condenser. (So I have 4 now, 2 pushing, 2 pulling from the rad) neither really helped in this very limited scenario. I don't know if the vents will, but visually seeing the heat steaming out of them did give me hope, not to mention the temperature of the vents was MUCH hotter than other areas of the bonnet. Enough that one of the paint guys was unsure as to whether paint would stick to it long term. I'm sure that will be fine also.
