As the title says: will 19" rims and 35 profile tyres fit a Stagea and what width: 7.5", 8.0", 8.5"
Or are Stagea owners limited to 18" rims? And what width: 7.5", 8.0" or 8.5"
Who's got what and post pics if you have them.
:D
https://www.sau.com.au/forums/topic/211261-rim-size-for-stageas/
:D
I have 9" in front with 235/35, and rear 9,5" and 265/35
go 20s with 35 series tryes lol
seriously i have 18s and wish id gon maybee 19
Hi Depends where you are , my roads aren`t exactly smooth and i would be in trouble with bigger than 18"x 8, because you have no cussion and will bend wheels and getting them rerolled is a pain.
my car came with 18's alex ... then l went to 19's (looks good, ride & fuel was poo), then back to 18's (much nicer ride, fuel & handling).
If l got another stagea l'd go 20's and just slam the shit outta the car. There's plenty of room there for them.
just a question to the OP..
what makes your RSV a nismo spec?
its not just because you have a nismo sticker is it? or a nismo set of tachos or 1 or 2 bits of nismo gear?
people like that piss me off
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
