Hi, Has anyone had much experience with diagnosing creaky suspension. I have noticed the when traveling over bumps, in and out of the driveway and some cornering there is a creaky noise coming from the front suspension. Im not sure if it is from the shockers, swaybar bushes are the control arm bushes.
Under braking / acceleration there doesnt seem to be any noises which lead me to believe that the problem is not control arm bushes (Or maybe im just hoping this), From what i can tell could it be the swaybar bushes ? they seem a little deformed and worn but not too bad or do shockers make this type of noise also ?
The car has done 60k and everything is original so its probably about time that some parts need replacing.
Any ideas of what I should do ?? Remove the sway bar and see what happens or can I take the car some where do a propped diagnosis ? Let me know what experiences you have had
regards
Dan
https://www.sau.com.au/forums/topic/211280-m35-creaky-suspension/
regards
Dan
I have noticed it, sounds like something is loose, I was told it is common but poses no safety issues......
I know this sounds crazy.....but take it to pedders and get their $14 check. Their job is to find everything possible wrong so they can make a sale so they actually do a pretty thorough job. and when they are done get them to actually show you the problems on the hoist.
but don't get them to actually fix it of course
I like your way of thinking.........
Thats what I was thinking of doing Cheers
what on earth is a camber pin? bolt through a bush for a control arm? or didn't they really explain it?
camber is not adjustable except for a tiny bit at the rear so I have nfi what they are talking about
I had a knocking noise and that was down to worn bushes but I get a creaking noise and that may be on the shocks so I will investigate further.
Thanks, Did you get replacement bushes for the car ?, Which ones did you need to replace ?, How much ?
Did you replace the swaybar bushes at the same time ?
Edited by danwatt
yeah I replaced the swaybar bushes and the others were down around the bottom of the suspension tower
work carried out by Autolign here in Auckland for $NZ 461.25 but I paid $200 approx extra for parts ex Nissan Japan
Autolign carries sway bar bushes for this car as these commonly go
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
