I had my 260RS dynoed and checked over today including compression test. PowerFC maps were checked and "tidied" up. Everything was good - drove it home then did some shopping etc.... Then went to a town just outside Adelaide for dinner, when we jumped in the car to go home it cranked over but nothing.
After checking nearly every connection and fuse I could then finally getting a lift home to grab my OEM computer out of the GTR and going back to connect that up to eliminate the powerFC, and removing the valley cover to check the wiring for the coil packs etc I came up with nothing. The fuel pump sounds like it's working, all lights on dash light up but no go.
Any ideas? I'm really worried about my car sitting there all night.
https://www.sau.com.au/forums/topic/211295-car-stranded-wont-start/
with the car on ACC (but dont try to start it) on the hand controller goto ETC, SENSOR SW CHECK
do you see any sensors highlighted with black background?
why not get the car towed back home so its safe... ?
Thanks for the help Paul, but still don't have a hand controller as per a previous post regarding fuel/boost cut. Not having much luck with this car - and I'm not in the RAA (or RACV for other states) and doubt I'd get a tow where the car is. Thing is though - surely if it were a powerFC problem connecting up the R32 computer would fix it?
I know there's 20+ of these "car won't start thread" but not many have the fix so thought I'd add the fix for any that care!
Well after leaving the car there overnight and not getting much sleep went back this morning. Checked the fuel pump - working good. Checked all plugs again - all good. Then after almost giving up checked all the fuses and found the one for the engine (I know - derrr!!) blown. Should've checked these 1st really but at 10pm at night in pitch black it's a little difficult to see.
So anyway car is good...
$Hit hey! I actually had that fuse blow on me whilst i was driving one day hey!! Just pulled around the corner and every thing just went stop!!!
Not sure if this is going to help, but once I was stranded at the petrol station on the hume highway going towards Casula, same thing couldn't start my car. So I just disconnected the air flow meter and put the ECU into LIMP mode and drove the car back.
Turns out my AFM was stuffed & also my injectors were clogged. Got a 2nd hand AFM off SAU and got my injectors ultrasoniced and yeah... all good now.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
