Hi guys,
Getting some mixed up torque specs for ARP main studs in RB25's and RB26's, obviously ARP's guide lines are MUCH tighter than the regular fairly low torque RB mains.
Can any of you guys confirm specs on the ARP main stud torque? or maybe give the specs for the tomei studs just for interest sakes?
Thanks
https://www.sau.com.au/forums/topic/211299-arp-main-studs/
Its for a 25DET
The studs are 1.5 pitch into the block, and the nut is 1.25 pitch, 10mm
They appear to be 190 000psi, the 3 slightly longer ones are identical to my Datsun A15 head studs! which call for 60ft/tq
on the ARP spec sheet the only 190psi 10mm stud they list is 60ft-tq, the 170/180kpsi require 42ft/tq which is right on 56nm, very close to the stock spec!
https://www.sau.com.au/forums/topic/211299-arp-main-studs/#findComment-3737634
SR20 + ARP = helicoil
Stuff helicoil, try cracked oil galley, or better yet, trying to line bore 1/2 ally 1/2 iron mains. I would never use any aftermarket main on a SR20 again, I have about 30-40 SR20's pushing over 300wkw on stock main bolts, never had a problem. RB's on the other hand use rather dinkey mains :-)
Must admit, im still very fond of my SR20's, somthing about a nice 276 HKS cam set, nice ported head, strong bottom end, good managment and a GT3076R .86 running 1.8bar makes for a very fun ride!
Edited by Rezlo
https://www.sau.com.au/forums/topic/211299-arp-main-studs/#findComment-3739005
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
