room will be the problem on that one. glovebox is VERY doable OR centre arm rest OR if you want to remake the rear seat centre section it would fit there. in dash - not easily.
as for quality same as the 8000.
  • Replies 44
garmin is RF based. no IR beam. the tv is IR. as for IR placement for the DVD unit - your call where it is placed. I have been putting them INSIDE the AC display to hide them - some are too big to do this though. any of the IPOD ones I do that is where they are. (oaksey if you are reading this that is where yours is.)
I see, I thought garmin was IR based too.
Is it possible to splice the TV's IR input wire so the same IR sensor would provide input for two devices? as long as the IR codes between the two device doesn't overlap each other...?
Alternatively, maybe you know of an in-car DVD player with an RF remote, that way it can be tucked away in the boot (something that takes like 6-10 dvds stacker), close the the pure tv's 2nd AV input.
nope separate sensors. I have a trick that I can use that WILL combine them but it involves another unit.
know of a 10 disc dvd unit but I'll have to see if it is still available.
Can you find out Chris, if the 10 stacker is a standalone (do not need a matching headunit) then I'd be interested. Is the remote RF? if so that will be a lot easier than trying to route another IR sensor to the front. pm me price to VIC delivered. I'll sort out installation here. cheers.
  • 4 weeks later...
Under the seat had the air-con vent thing, and it seems a little cramped under there. Was afraid it might get in the way if seat was moved back and forth. Plus people with dirty feet will kick it all the time.
I secured it with velco strips so I could move it anywhere if i don't like the position right now.
Forgot to thank you Chris for all the advice you've given me. You're a gem for V35 owners! :P
Ok guys one quick question regarding the head units being used.
In order to get the right input to the monitor (i.e. NTCS signal) are you using a US dvd player or some headunit that has NTSC out capability available here in Aus? Ive noticed a couple of said units available through Nesavision but they dont really do it for me and look a little boring. My thought was to look at getting hold of a headunit from the US and hooking that up. Would there be any problems with doing this?
From what i can see radio band frequencies are all similiar and the only difference would be the regionality of the DVD i guess?
unit needs to support local radio and local DVD regions. the USA versions do not. I get 2-3 questions a week on this and then 1-2 I should have listened replies.
dont really know what looks have to do with it. the unit is usually under a closed panel anyway.
Thanks for that, sorry to cover old ground but now i know for sure!
Cheers
I bought this unit from the US.
http://www.gooddeals18.com/c=T4pIjUKR7HKU5...oduct/PLD175TBT
-Bluetooth Handsfree
-DVD - I've only put in a burnt DVD so far and it works. Divx works too.
-MP3
-Radio - ALL aus channels
-USB + SD Card Slot
-NTSC TV Tuner - doesnt pick up Aussie channels
I'm one of the guys that gave chris one of the "should have listened replies" cos I complained to him that the TV Tuner didn't work. I really wanted the TV. Thinking about getting the Nesavision one just for that.. But I'll stick with this one for now. Only cost me $AUD 150 shipped.
  • 5 weeks later...
Hi guys,
I wanted to know where are the AV inputs in the car located, is there one on the back of the BOSE unit (i have the premium pack, no camera).
What i am going to do is just run the AV leads to my mobile phone so i can plug it into the system.
I have the Nokia N95 8gb, i think it a good solution for my self without any extra cost. So far I have 350 songs, FM Radio, some movies and GPS on the phone so it coveres what i need.
So where is the best location to connect the phone?
Thanks Chris,
The AV lead, can i purchase that in Sydney?, or is it something you have custom made yourself?, if so can you please PM a price including delivery to Sydney.
Im not sure what you mean when you say "rear deck - drv side"??
tv tuner location is what I meant- under rear parcel shelf drivers side. av lead is a special thing i import from overeseas. makes audio into these cars plug and play.
I found a 6 stacker quite a reasonable price: http://www.brashimports.com.au/DV680.htm
The install instruction is easy to follow so I wonder if I can tap to the existing DTV tuner power source as they'll be adjacent to each other in the boot?
but i'm not quite sure how to differentiate:
a) power ground
b) chassis ground
also what to do with the parking brake lead where can this connect to?
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
