  • Replies 51
Guest RedLineGTR
i dunno but they looks sweet...i think it's a Nismo Aero wing..NismoR34 might be able to shed some light on it but dunno. I"ve seen cars with em in Vic but i think the only way to get them here if someone is selling one or you get a place to make a copy of one for ya.
Yeah I was thinking the GTR wing to beging with but then I saw those pics and it's a factory nismo kit like mine. Thought it might match nicely. Damn it's huge though, maybe if I angle it properly I could launch the car, haha. Could be handy for that peak hour traffic. Any other suggestions instead of the Areo II wing?
I agree with most above comments Adzmax.
Its a nismo factory option wing, along with the rear bar, side skirts and front bar.
I like all of these options except for the wing, where I agree with R34GTT-R
But at the end of the day, its up to you - do what YOU want mate!
I have seen some JAP parts importers advertising 34 bits such as factory wing like mine for around $300-400. In Adel. & Syd mainly. I think it was Just Jap in Adel actually. CHeck the usual websites - links in Vic section ;)
Everybody has been saying it is a Nismo kit, but it is not. It is Altia and if you are happy to shop around, some Chinese shops might be able to get them. If not, try Nissan dealers (Blackburn, Ferntree Gully) because the last time I checked, they can get Nismos and Altias for you, since they have some kind of collaboration with Nissan Japan.
PM me if you need help, I might be able to get one for you...
Hey there E, you still O/S?
I dont see why Altia would copy Nismo so closely - they look the same, the skirts are definately Nismo ones, unless altia copied them too :confused:
If you ask me the bodykit and wing are all either nismo copies [altia] or nismo.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
