hey guys, currently in the process of installing my intercooler. does anyone have pictures of their R34 intercooler install, particularly how much, if any, you had to cut off the stock front bar?
cheers.
EDIT: any hints and tips at all are greatly appreciated, as me and Jenkies are pulling eveything apart RIGHT NOW!!!!!
Edited by Damo_R34
https://www.sau.com.au/forums/topic/211344-cutting-front-bar-for-cooler-r34/
The more you cut out of your front bar, the more air can get to you intercooler. The more air, the more better it works. However, watch how much you cut out, because it can look hidious if you go too far. Also, cutting the bottom of you bar off is the stupidest thing you can do, because it will cause air to run underneith the cooler, instead of thru it. Air will always take the easiest way thru, just like electricity. Hope that helps, good luck with it. Have you looked int the R34 Gallery yet? You'd find quite a few in there I reckon
