Hi R33 GTST
I sent PM.
Thank you
siddr20 - Just very curious about 1 thing. You've got such nice results whether it was before or after, but how did you manage to get 183kwrw before hand with those mods man? I dun get it, does the fuel pump help with power that much? or was the dyno inaccurate? and with the re-map it musta actually made like 20+ kw push?
Hi
I had my car dynoed at 183kw with full exhaust and pod filter as the only mods. This was at unigroup. I think my boost pressure was 10-11psi.. Had a manual bleed value so they kept adjusting it from 8psi (What i had) to 11psi. Turned it back down to what i had after the dyno.
Also went to the drags after this with just those mods and got 14 flat with street tyres.
Since then i have fitted r34 side mount, walbro fuel pump and thats it i guess.
Bleed value set at 10psi for remap.
WELL my stupid 22 dollar blleed value wouldnt go any higher.
Then went to toshi and got it remaped.
Felt a huge difference straight away. Got it dynoed few days after a local tuner shop. The actually feels like a 200kw car.
Went to wakefield the day after dyno and with shitty rubbers (stock rims) i got 1.13. With proper lap timers. SO the car deff has a lot of power :banana:
To answer your question i would upgrade the fuel pump :teehee: To be on the safe side. Otherwise your car might be leaning out too much.
Edited by siddr20
Had a few pms asking me what my fuel economy was like.
Well i have been getting consistent 400-420kms per tank.
Most of it being city driving with traffic and 1/4 of it highway to uni and back..
Hope this helps :blink:
  • 4 months later...
hey there! been reading this for 2 days now! and this seems excellent! espciailly siddr20, u seem to be loving it! i currently have a r33 Series II with Blitz POD filter and BLITZ LM cool, Trust Greddy Power Extreme II Catback, Trust/Greddy front pipe 3inch, 3inch High Flow Cat, Turbotech Bleed Vavle.. how much power am i looking at there? Because my car is using alot of petrol and my exhaust sometimes makes a big poping noise obviously it means its running rich.. Can toshi fix this issue? The bad thing is im melbourne?.
Hey there, your problem is you need to invest in some spitfires and get your spark plugs re-gapped.
  • 3 weeks later...
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
