Hi R33 GTST
I sent PM.
Thank you
siddr20 - Just very curious about 1 thing. You've got such nice results whether it was before or after, but how did you manage to get 183kwrw before hand with those mods man? I dun get it, does the fuel pump help with power that much? or was the dyno inaccurate? and with the re-map it musta actually made like 20+ kw push?
Hi
I had my car dynoed at 183kw with full exhaust and pod filter as the only mods. This was at unigroup. I think my boost pressure was 10-11psi.. Had a manual bleed value so they kept adjusting it from 8psi (What i had) to 11psi. Turned it back down to what i had after the dyno.
Also went to the drags after this with just those mods and got 14 flat with street tyres.
Since then i have fitted r34 side mount, walbro fuel pump and thats it i guess.
Bleed value set at 10psi for remap.
WELL my stupid 22 dollar blleed value wouldnt go any higher.
Then went to toshi and got it remaped.
Felt a huge difference straight away. Got it dynoed few days after a local tuner shop. The actually feels like a 200kw car.
Went to wakefield the day after dyno and with shitty rubbers (stock rims) i got 1.13. With proper lap timers. SO the car deff has a lot of power :banana:
To answer your question i would upgrade the fuel pump :teehee: To be on the safe side. Otherwise your car might be leaning out too much.
Edited by siddr20
Had a few pms asking me what my fuel economy was like.
Well i have been getting consistent 400-420kms per tank.
Most of it being city driving with traffic and 1/4 of it highway to uni and back..
Hope this helps :blink:
  • 4 months later...
hey there! been reading this for 2 days now! and this seems excellent! espciailly siddr20, u seem to be loving it! i currently have a r33 Series II with Blitz POD filter and BLITZ LM cool, Trust Greddy Power Extreme II Catback, Trust/Greddy front pipe 3inch, 3inch High Flow Cat, Turbotech Bleed Vavle.. how much power am i looking at there? Because my car is using alot of petrol and my exhaust sometimes makes a big poping noise obviously it means its running rich.. Can toshi fix this issue? The bad thing is im melbourne?.
Hey there, your problem is you need to invest in some spitfires and get your spark plugs re-gapped.
  • 3 weeks later...
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
