Dunno about you loom question as I'm getting my whole Microtech LT12s wired up completely. As for your 'easy conversion' question - if you are putting a standard RB25 in it will fit perfectly with no problems at all. If you are putting on an aftermarket plenum (like my Greddy one) you have to move the master cylinder along about 1 inch. There are a couple of other fiddly bits but so far everything is coming together fine. And I'm guessing you are putting in a 25 gearbox? Well, you will have to make up/modify your gearbox crossmember as it doesn't fit and you will have to get an RB25 slave cylinder as well. Don't know about the speedo as my conversion is about 3/4 finished but I believe we have to get a Nissan Navara speedo head? There are heaps of topics on here regarding the conversion........
the search function is your friend.
There were a lot of guys doing this swap a couple of years back.
Search the tutorials section for a thread by predator. It'll be the most comprehensive write up on the actual engine swap. There are a couple of good threads on the gearbox and speed sensor swap in this section if you look at page 2 or 3 i suspect.
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
