  • Replies 58
Posted Images
how much for the front left stub axel?
$80 for FL stub axel, i'll give ya the whole hub assembly
How much for the drivers side window switch surround?
Still have the switch surround but it's scratched and has a small crack in it, PM if interested
have you got floor mats?...or air freshners? ...how about passenger side seat? any aftermarket goodies?
No floormats sorry, didn't come with them :( Have the passenger side seat but looking to sell them as a pair at the moment. Only aftermarket part is the front pair of Tein HA coilovers. pics coming soon
dibs on instrument cluster!!
dibs dibs dibs
PM sent
dash gear surround w/ leather boot and cig lighter - $50 ill take this just pm with price to send to gold coast thanks
PM replied
Dibbs on dash surrounds! u have PM :)
pm replied
im guessing the front bar is smashed?
pm me if available in good nick :)
Yep it's smashed up on the left side, Could probably fix it if you were inclined heh
I'll take the instrument cluster if other sales fall through :)
Looks like it's sold but i'll let ya know
interested in the cluster if still up 4 sale...
how much for postage to liverpool area?
I am keen on the rear brake calipers...
Pm sent
Cheers
I need the B Pillar covers, Drivers side Interior Triangle and the black plastic interior bolt covers (for seats and belt, from memory they are 17mm).
PM sent!
intrested in the steering wheel. post to melb ok ??
Yep, don't mind posting it. Pm sent
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
