  • Replies 58
Posted Images
hey bud,
can i buy the whole lot of the seat belts with brackets n bolts, both front & rear.
i live in Cairns, so if u dont mind having to post i'm happy to pay:)
cheers Daniel.
p.s can u pm me ur number
PM sent
PM sent
Pm replied
Any 5 stud wheels??
Just have 1 pair of 5 spoke 17's in silver. Can get pics if you're interested
List updated, few prices dropped :)
pm sent about that cat
Pm replied
still got RHS headlight?
Sorry mate it's sold to J'z-R33 :P
Yeah can you send me some pics please? How much you after for the pair?
Thanks.
Heres a pic:
Pm sent
hey mate
if you don't mind selling the Snorkel alone with no airbox, i would be interested :rofl:
PM when you get the chance with a price :P
At the monent just looking to sell them together, I'll let ya know if i decide to seperate
any chance you have the unleaded fuel restrictor neck?
Kent
Is this what you're after?
If so, yep. $40
Hey guys
picked up another R33 Skyline for wrecking. It's had a knock on the front left so the bonnet, left guard, headlight, etc etc are gone
Rb25det turbo engine- has 93000 k's. Has had new Gates timing belt installed @ 63,000ks..
Compression tested this engine, good results accross all cyl: 154 155 153 154 155 154psi
Complete motor, wiring loom, S2 turbo/lines Sold
5sp Manual conversion kit (5sp box, clutch, flywheel, tailshaft, pedals, clutch master/slave cyl & all lines) -$1900ono
everything ya need to convert an auto to manual!
Series 2 AFM (pink sticker) - $120
window washer bottle - $20
radiator overflow bottle - $20
Engine bay fuse box cover - $30
3" dump/front pipe combo $100 PICKUP!
3" Catco cat, 487CFM - $80
3" catback exhaust - $160
Drivers side S2 foglight/indicator Sold
Aircon compressor $120
coilpack cover $40
standard airbox + snorkel $90
Brakes/Suspension bits:
Power steering rack - $125
castor rods - $80 pair
TEIN HA front coilovers - pair $350 Sold
stock rear shocks/lowered springs - $150 pair Sold
front rotors, top condition - $70 pair
front calipers - $300 pair
rear rotors top condition
rear calipers - sold
front hubs $80 each
rear 5 stud hubs - $160 pair
front upper control arms- $60 each
rear lower control arms- $70 each
rear upper arms - $50 each side
handbrake drum assembly + cables - $220 pair
stock viscous ABS diff - $250
driveshafts/halfshafts - $80 pair
hicas rack - $30
front swaybar - $20
rear swaybar - $20
rear cradle - $50
Exterior bits:
rear Skyline fascia, white - $40
bootlid, no spoiler, shaved boot lock - $150
fuel flap lid $15
Interior bits:
Instrument cluster - manual with 93000ks - $100 Sold pending payment
S2 airbag steering wheel, $225 ono
dash gear surround w/ leather boot and cig lighter - $50 Sold pending payment
climate control unit, as new condition $60
larger dash surround w/ clock, hazards etc - $100
Series 1 door trims - $60 each side
drivers side window motor -
handbrake boot, immaculate - $25
stereo mounting brackets - $25 pair
series 2 front seats in top nick - $200 pair
series 2 rear seats $80
glovebox - $30
floor carpet $80
centre console lid, perfect nick $40
seatbelts & buckles + bolts full set - $100ono
steering wheel surround plastics - $30
both headlight & indicator stalks - $40
parcel shelf - $40
complete boot interior (except piece that covers battery), good condition - $80
electric aerial $50
rear wiper motor - $50
PM for anything not listed!
Pickup welcome, or I can post anything as long as its not too big for auspost
Located in Sydney, near rockdale
cheers :(
hey im interested in your stearing column plastics and was also wondering if you the drivers side window switches at all
thanks Matt
Sorry to anyone who tried to msg me last night but couldnt, my pm box was full
hey mate do you have the passenger side door trim? also the latch goes into lock the door (attached to outer door) also ur location?
Cheers.
Yep, PM sent
How much for the relays from the interior fuse box, the 45amp fuse from the boot for the blower motor and the fan/blower motor. Thanks
Pm sent!
just wondering if you still have he front and rear seats, and if possible all the door and rear side trims also.
you wouldnt have the standard computer would you?
Yep i still have the seats and door/side trims, sorry no ECU though. PM sent
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
