Item:Bee*R Rev limiter
Condition:Used in excellent working condition, visibly looks near new.
Price:$230 including Reigistered Post Delivery anywhere in Australia
To Fit:Any car
Contact:Shay 0419 780 999 or shajar@iinet.net.au
Comments: This little device is handy for a few things, it mainly saves your engine by cutting ignition instead of Fuel as the ECU does when you hit a predetermined rev limit that you can set. This also helps if running in an engine, you can set the limit lower than standard. Good for drifters so they are not over revving continiously, has launch control when hooked up to the handbreak and if you into chitty-chitty-bang-bang with flames it can shoot flames out your exhaust (though the cat needs to be cleared out or removed for this to work effectively
URLS http://www.bee-r.com/english/revlimitter/instruction.htm
URLS http://www.bee-r.com/english/revlimitter/inst/index.htm
URLS http://www.takakaira.co.jp/asp/template.as...STtPqQqlnMokrNm
Edited by shajar
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....馃槳 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will馃ぃ馃馃お馃ぃ
    • If you squint hard enough those horrendous barracuda wheels look a bit like r33 GTR ones!
    • ....that still needs to be retrofitted to take R134A also.
    • The Frenchy's kit linked above, will cost you about the same as factory Nissan. The difference with staying factory Nissan is, you'll end up with an inferior AC system.
    • 50k for an auto series 2 now. Does have a battery so probably adds a bit.
