Item: Enkei Racing wheels 2 piece wheels, 17x9 +22 Offset (not sure which model) plus rubber Dunlop direzza 245x45x17 all round GTR Offset
Age: not sure came with car
Condition: fair condition, normal scuff marks, gutter marks
Price: $1200 or make an offer
To Fit: (What car) came off a R32 GTR
Contact: 0433 384 056
Comments:
Item: C's short shifter
Age: not sure came out of previous owned car
Condition: good
Price: SOLD
To Fit: (What car) R32 GTR not sure wat else it can work in
Comments:
Edited by SAM-32R
will the rims fit R33 gtst s2 ?
i got no clearance between guards and tyre at the moment im wondering with that size and offset if it will scrub?
how much tread is left?
iam not to sure on the offset, and iam not sure on whether they will fit on an R33 mate. sorri bout that
like i've stated iam not too sure on those details as they came with the car
and wen i took them off.. there were no info labels on them
, they have just under 50% tread all round left.
If it came out of a R32 GTR it should be:
ITEM # C 1309NL
ITEM C's Short Shifter for Skyline (BNR32/HNR32/BNR33/ENR33)
Good luck with the sale
they wont fit on a 33GTST without modification. 9inch + 20 on the front with 245s will be fouling on the guards for sure.
so is that the offset?
Hey mate, i honestly dont noe, i dont noe where Beer Baron got that from, but if
he's quite certain about it then i'll take his word for it. your more than welcome to have
an inspection if ur intrested mate, but they are the same offset all-round, thats all i could tell u
as for the exact measurement, i dont noe
have a crack at measuring the offset:
http://www.chevellestuff.com/tech/wheel_offset.htm
not many people want to buy a wheel not knowing its offset so it would probably help heaps with the sale if u could find out. im semi-interested pending offset.
Thanks for the tip mate, but as i was following the instructions, turned over one of the wheels
and it actually had all the measurements imprinted on the wheel itself lols
soo it's 17x9 with +22 offset as it is imprinted on all 4 wheels, hope this helps everyone intrested now
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
