Item: Enkei Racing wheels 2 piece wheels, 17x9 +22 Offset (not sure which model) plus rubber Dunlop direzza 245x45x17 all round GTR Offset
Age: not sure came with car
Condition: fair condition, normal scuff marks, gutter marks
Price: $1200 or make an offer
To Fit: (What car) came off a R32 GTR
Contact: 0433 384 056
Comments:
Item: C's short shifter
Age: not sure came out of previous owned car
Condition: good
Price: SOLD
To Fit: (What car) R32 GTR not sure wat else it can work in
Comments:
Edited by SAM-32R
will the rims fit R33 gtst s2 ?
i got no clearance between guards and tyre at the moment im wondering with that size and offset if it will scrub?
how much tread is left?
iam not to sure on the offset, and iam not sure on whether they will fit on an R33 mate. sorri bout that
like i've stated iam not too sure on those details as they came with the car
and wen i took them off.. there were no info labels on them
, they have just under 50% tread all round left.
If it came out of a R32 GTR it should be:
ITEM # C 1309NL
ITEM C's Short Shifter for Skyline (BNR32/HNR32/BNR33/ENR33)
Good luck with the sale
they wont fit on a 33GTST without modification. 9inch + 20 on the front with 245s will be fouling on the guards for sure.
so is that the offset?
Hey mate, i honestly dont noe, i dont noe where Beer Baron got that from, but if
he's quite certain about it then i'll take his word for it. your more than welcome to have
an inspection if ur intrested mate, but they are the same offset all-round, thats all i could tell u
as for the exact measurement, i dont noe
have a crack at measuring the offset:
http://www.chevellestuff.com/tech/wheel_offset.htm
not many people want to buy a wheel not knowing its offset so it would probably help heaps with the sale if u could find out. im semi-interested pending offset.
Thanks for the tip mate, but as i was following the instructions, turned over one of the wheels
and it actually had all the measurements imprinted on the wheel itself lols
soo it's 17x9 with +22 offset as it is imprinted on all 4 wheels, hope this helps everyone intrested now
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
