  • Replies 64
I think they supply a spacer/adapter plate for the 3071r
but they have a 2871r that they say is a T3 direct bolt on, with only adapters for oil and water required.
http://www.tweakit.net/shop/product_info.p...roducts_id=6596
i thought the garret's didnt come in T3
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3738207
Obviously they have sourced reproductions of the RB25 and VG30 housings, mating them up to Garrett cartridges. That gives the advertised 0.63 and 0.71 A/R.
GCG and HPinabox are doing similar products.
Simon-R32 is running the 3071, which comes with the 56.5mm cropped version of that turbine. It also has a 0.5 A/R comp cover, which is big enough to flow 280 rwkW. I would suspect that the larger 0.70 cover used by tweakit is being used purely for underbonnet bling and it will necessitate the use of a spacer plate for the turbine mounting just to get clearance from the manifold.
I ran a 2871 hybrid similar to the tweakit version. Not hard to fit up, and gave plenty of responsive poke.
FWIW, those power claims each seem a bit high. But they'd likely do a pretty good job for the money. Just another option out there in the market.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3738455
that appears to be the exact same turbo that i got from GCG. if thats the case then you'll expect excellent performance from it, its not laggy at all and can make the numbers! Mine is making 280 rwkw atm on 17 psi
Does yours have the 1.06 exhaust housing, when does it hit full boost?
I have contacted them about this, apparently it is a garret housing.
dont forget to add the fitting kit (the option is down the bottom) which will cost you an extra $680 to make it a bolt on.
i am looking at getting one of these after i have rebuilt my engine.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739616
The sum of the parts of the fitting kit doesn't equal the $680 price tag. The base turbo is certainly cheap, but once you add in the fitting kit you may as well talk to your local turbo supplier as the price will balance out.
Just a word of warning for the uninitiated: The specs listed for that turbo are not 3071 specs. If you want to see the proper specs then go to www.turbobygarrett.com and look up the 3071. It lists both the cropped and uncropped versions.
I have no idea why you'd want to run a t04s comp cover on a 3071. The fact that it's listed with a .7 cover makes me think they either don't know what they are listing, or they have mislabeled the turbo. The one in the pic is a t2 flanged i/w version of a 3071 though. 550hp is a bit optimistic as well.
the .71 turbine housing is most definately not a genuine garrett unit, though there's nothing wrong with them if simons results are anything to go by.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739748
No mine has the .71AR rear housing. full boost at around 3500 rpm. sure its a cropped turbo, but my results and findings have been in several threads now... its a good turbo
if i were to do it all again i'd go a proper 3071 hands down.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739774
whats a proper 3071 then? cause il be buying one real soon.
if its a non genuine garrett unit with the .71 rear housing what are the right specs.
would i be better off going for the 3076r? as i am looking for about 280rwk on 16-17psi or so.
Edited by R33GOD
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3739907
I spoke with HP/box and there version of the 3071 has a .50a/r comp 56t wheel but the exh a/r was a.73 which they custom build and he couldn't even remember the exh wheel size/trim which leads me to believe it's the cropped one, but overall it seems like a good turbo, bolts to the stock dump and manifold with a 10mm spacer, oil/water lines need making.
Edited by turbomad
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3771936
I am about to organise a group buy through garrett for a bolt on kit they designed for the RB25
I have the prototype on my car making 295rwkw.
The kit is a direct bolt on and is also rated to 550 hp. It will also come with a dump pipe.
Cost is in the ballpark of $2500. Makes full boost (18psi) by 3100 rpm.
Do you guys think there will be much interest?
Min purchase is 5 at a time. I have sold 2 already, if I get another 3 interested the group buy will go ahead.
Obviously more specs will be posted if there is any interest.
does it come with the fitting kit?
im assuming it is the same turbo as here http://www.tweakit.net/shop/product_info.p...roducts_id=6598 and that one with fitting kit would still come in under 2500 delivered.
is there a difference between yours and theres and can you do a better price with out the dump pipe as most people want one of these so it will bolt up to the dump pipe they already have.
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772059
I'd be interested to see whats in the kit.
All installed inc fabrication of new intake piping (which is incomplete, no bov or bov return atm), new dump and front pipe, turbo, lines silicone joiners i didn't already have lying around, spacer, new studs, gaskets, nuts i reckon ball park 2900 cost all up, 3k if you do the head/manifold gasket.
edit, you posted while i was typing. stock lines would save 250 on their own, though i'd be interested to see it. how do you get around the spacer issue with stock lines?
Edited by BHDave
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772082
i'm interested in seeing more ever since you originally posted the results trooper.
interested in whether this ends up being a 52 trim 76mm compressor when someone pulls one apart.
if they are a bolt on and your results are duplicated they will sell like hotcakes.
+1 for interest here
Edited by wolverine
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772097
Trooper ages ago when I asked your contact he said it had a sleeve pressed into its turbine housing which was re-profiled to suit the cropped GT30 UHP turbine . At that stage the proper Garrett petrol spec GT30 IW T3 flanged turbine housings had been not been released so at times less than perfect alternatives were being used . He did quote its Garrett BB CHRA number and I don't recall which one it was other than it had the cropped turbine .
The real GT3071R can be bought or I should say ordered with the designed by Garrett GT30 turbine housing and you'll know its a complete factory matching assembly . Not machined or altered in any way other than its original design parameters .
To make a real IW GT3071R kit for an RB20/25 is straightforward . The water and oil fittings are the same for any GT BB Garrett turbo from GT2554R up to GT3582R because they all use the same bearing housing .
One you have the spacer and fasteners to get the compressor housing off the exhaust manifold all that's left is the air in/out plumbing and the exhaust outlet pipe .
I'm surprised that at this stage no ones made jigs and produced dump pipes to mate a GT30 IW turbine housing to an R33's engine pipe . The genuine GT3582R IW turbine housing uses the same outlet flange dimensions so such a dump pipe could easily cover the whole GT30R/GT35R range meaning the real GT3071R , the real GT3076R and the GT3582R . You could buy it once and know it suits turbos from ~ 420 - 650 horsepower plus and bolts straight onto an R33 RB25DET with any of these turbos .
Anyhow Trooper I don't know if the turbo you are talking about is the same as the one you had when we last spoke but if it is there are issues with non factory turbo components if they need to be replaced at short notice . One down side is that it chains you to the mob who produced it and if you fall out with them or can't reach them its a bad outlook .
To each their own , I'm waiting for the results of the real GT3071R with the genuine Garrett GT30 IW 0.63 A/R turbine housing on an R33 RB25DET . As an all rounder for your typical R33 driver I think it should be pretty good .
Time will tell , my opinions only cheers A .
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772145
Trooper I think that if Garrett Sydney want to generate some interest they are going to have to show what they're offering or it all remains a mystery , and many perceive mystery to be risk .
I know there is also risk involved with copying and undercutting but once there are a few sets in circulation the cats out anyway .
I'm mildly curious to see what they've come up with but it would have to be something pretty effective and convienent to separate me from my money .
Over to you , cheers A .
https://www.sau.com.au/forums/topic/211431-garrett-gt3071r/#findComment-3772801
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
