Hi Guys
Im lookin to fit a short shifter to the 260 fairly well as soon as i get the car. Which ones fit? R33 GTR? would a 33 GTST fit? not sure if there are any differences between the two as far as shifters go.
Have driven a 33 with a short shifter, found it to be fantastic.
Is there much difference between $300 worth of nismo/HKS and a $80 ebay item? realistically from what ive seen, its jut a shaft and pivot point - not much that can go wrong as long as the dimensions are the same.
THanks in advance, guys.
https://www.sau.com.au/forums/topic/211439-short-shifter-for-autech-stagea/
yeah ive heard something about stress on synchros but nothing solid... Would realy liketo have one tho, but not willing to risk gamaging anything for it tho.
Anyone know?
*waits for SK... darrin... brad...*
i cant comment as i dont have a short shifter, i have read the cheap ones are shit and the good ones even cause issues with getting it into gear on hard shifts etc but this is hear say and not from personal experience. I can say i still smashed 3rd gear on wed night with a stock shifter, lol, what a pain in the arse i didnt even get 1 full drag pass in before it busted :thumbsup:
There are two types - the Nismo one and others
The nismo Solid shifter reduces the throw by 25% and is much better than all the others in the quality stakes
Most of the rest only reduce throw by 10% so are hardly worth fitting anyway,
If the box is perfect with none of the crunching into gears (especially 3rd or 4th) then the nismo one will be ok as the box is not worn and the results are excellent
If however there is already any crunching leave well alone as a different gearstick wont solve a problem that is in the gearbox
These gearboxes do not have the best change in the world and if worn the short shifter kit can make matters worse especially if its a cheap ebay item.
indeed. all short shifters cause more damage to the synchros than the normal shifter - quicker shift = synchros wearing faster, its that simple.
its just not worth $3k for a new gear box
how does a different pivot point cause issues? still moves the linkage the same distance, just a different ratio due to a higher pivot point... doesnt make logica; sense that that would create issues.
for the most part i guess, in most cases, but im just after the shorter distance. I found that when i was driving the skyline i didnt exactly snap through gears, but i enjoyed the more solid and direct feel.
We'll wait and see when i get the car first - hopefully the shifter doesnt feel like a broom handle in a bag of marbles. Looking at the close up pics of the stock shifter thats in it, its only a fairly short shaft, not that that has much of a bearing on throw distance. The short shifter in the skyline was standard length, but shorter throw.
well yours is the real thing so it might be different, but I'm guessing it just runs a standard 33 gtr box and shifter (I am running 32 gtr but they are the same shift wise). I find it fine.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
