Has any one, when removing the gauze section from their Air flow meter, still got it in good condition.. As i am having idle problems and i trashed mine getting them out.. let me know (PM) or email me Sil8tys email Will be greatly appreciated, do expect to pay for it or swap...
PLEASE SOME ONE HELP...... ;)
https://www.sau.com.au/forums/topic/21145-r-33-air-flow-meter-gauze/
RedlineGTR: yeah tried that, but it made no difference.. It stumbles a bit at idle.. Will fit the front gauze back in (before sensor) to try and make the air flow more uniform through the sensor.. Thanks any way.. :)
GTST4G: Have PM'd you back.. Greatly appreciated.. :)
Taking the gauze out shouldnt make any difference to your cars peformance other than getting that tiny bit extra out of it due to there being less of a restriction. Id try cleaning them first with carby cleaner. Take them out, give them a real good soaking spray once or twice or even 3 times! it's amazing how much oil and crap still comes off them after a 3rd spray. You can see this discoloured cleaner dripping out. Dont let the cleaner liquid sit in the point where the a/f element mount joins the outer casing. It should be sealed anyway but just incase.) then reset your ecu again.
The gauze is there for catching foreign material entering the meter. It's that thin that it wouldn't have any flow straightening properties at all. I would have thought it would create a (uniform) turbulence instead of straightening the flow.
It wouldn't really matter taking them out and loosing the protection properties of gauze because one would think that if you could afford to take your car to a point where you would start blowing turbos, then one would be able to afford a new airflow meter aswell as a new turbo setup and anything else that was damaged in the process :D
Cheers
Richy
RichyR32GTR: tried all that, have spoken to a few reputable people/workshops about this.. Tried resetting Computer, no go...... Got told to try fitting the gauze in after the filter to see if it MAY fix my problem, as it is possible that different filter designs alter the way air flows into the A/F meter (mine is the APEXi Power Intake filter) As it never did this prior to removing the gauze out of the A/F meter.. I did notice a fair increase in boos though.. Will keep you posted to how it goes....
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
