Hi guys
Not sure if this trend have been posted before and probaly a stupid questions.
But I just want to know what fuel you guys usually use with the Skyline and have you notice any differences in milage, power, idle etc.???
I have always pumped Shell Optimax as I though they have the highest octane and some cleaning agents in it. But I just found out in some other treds that some people also use BP Ultimate and Mobile fuel.
If it is the case I'm more happy to change to BP as it is right next to my place and is cheaper than Optimax.
Cheers
if you're ever anywhere near a place that sells evolution 98, try it out. i get measurably lower knock values on the pfc when compared to mobil and bp stuff. optiomax was worst of the bunch for me.
Adrian
Guest RedLineGTR
Originally posted by CerealKiller
yeah this has been questioned many a time before.
Optimax has reduced in quality the RON rating is variable servo to servo. The most consistant seems to be BP Ultimate and Mobil Syngery 8000 which are both 98RON.
sounds about right bro..
Guest RedLineGTR
Basically i would recommend to type other fuels at least once. Some cars run better on certain types and some dont but Optimax is rated at a max of 98ron when brands like BP ultimate are rated at 98ron or more but in most cases they arnt much more than 98ron+. Alot of people have at alot of bad batches of optimax etc. My 2 cents.
Thanks for the feedback guys.
I think i will make a switch to BP Ultimate. But doesn't all BP as Ultimate now instead of Premium Unleaded?? I'm only guessing because the Ultimate would replace the P.Unleaded, like Optimax replaced their P.Unleaded.
Cheers
I know this may upset some people but in my experience, I tried
Shell Optimax and it was the worse thing I could have done.
Quality changed from servo to servo, and in fact the car lost power. I am not sure if it is related but my Oxy sensor went bust and had to replace it. Read some guys had problems with Optimax and blew their Oxy sensors as well. Like I said, I am not sure it is related to Optimax. I swicthed to Ultimate and car runs smoother and stable fuel economy. I haven't tried anything else.
very intresting comments....i have been wondering for a long time what the superior fuel is....i have been using optimax since i bought the skyline, almost 2 years, not really had any had problems, however after reading the above comments i am eager to experiment with BP and perhaps Mobil.
its all the same LOL ... just try most of them out ... u will find that different cars will react differently to the petrol depending on the way its tuned ... i've tried lots of petrol in my car ... just about all i can think of .. even normal unleaded for half a tank to see how i went ... needless to say ... not good in terms of mileage and power ... the best for me is regular pulp .. bp that is ... probably the cleanest is bp out of all the brands from what i know ... low sulfer or whatever their advertising is ... but yeah i use that cause its 5cents cheaper and gives me more economy ... beats me why?? hehe .. i want to know how these engines will react to all this ethanol the government is trying to support for the poor sugar growing farmers ...
Prediction:Federal Government legislates that all regular fuel must have a small % of ethanol. Premium Fuels exempt , HOWEVER a new levy (read TAX) to be introduced to "offset negative revenue stream". (Because they know there will be little effective opposition. The fuel companies will go along with it and the media couldn't give a stuff)
[/cynicism]....:D
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
