Hi guys
Not sure if this trend have been posted before and probaly a stupid questions.
But I just want to know what fuel you guys usually use with the Skyline and have you notice any differences in milage, power, idle etc.???
I have always pumped Shell Optimax as I though they have the highest octane and some cleaning agents in it. But I just found out in some other treds that some people also use BP Ultimate and Mobile fuel.
If it is the case I'm more happy to change to BP as it is right next to my place and is cheaper than Optimax.
Cheers
if you're ever anywhere near a place that sells evolution 98, try it out. i get measurably lower knock values on the pfc when compared to mobil and bp stuff. optiomax was worst of the bunch for me.
Adrian
Guest RedLineGTR
Originally posted by CerealKiller
yeah this has been questioned many a time before.
Optimax has reduced in quality the RON rating is variable servo to servo. The most consistant seems to be BP Ultimate and Mobil Syngery 8000 which are both 98RON.
sounds about right bro..
Guest RedLineGTR
Basically i would recommend to type other fuels at least once. Some cars run better on certain types and some dont but Optimax is rated at a max of 98ron when brands like BP ultimate are rated at 98ron or more but in most cases they arnt much more than 98ron+. Alot of people have at alot of bad batches of optimax etc. My 2 cents.
Thanks for the feedback guys.
I think i will make a switch to BP Ultimate. But doesn't all BP as Ultimate now instead of Premium Unleaded?? I'm only guessing because the Ultimate would replace the P.Unleaded, like Optimax replaced their P.Unleaded.
Cheers
I know this may upset some people but in my experience, I tried
Shell Optimax and it was the worse thing I could have done.
Quality changed from servo to servo, and in fact the car lost power. I am not sure if it is related but my Oxy sensor went bust and had to replace it. Read some guys had problems with Optimax and blew their Oxy sensors as well. Like I said, I am not sure it is related to Optimax. I swicthed to Ultimate and car runs smoother and stable fuel economy. I haven't tried anything else.
very intresting comments....i have been wondering for a long time what the superior fuel is....i have been using optimax since i bought the skyline, almost 2 years, not really had any had problems, however after reading the above comments i am eager to experiment with BP and perhaps Mobil.
its all the same LOL ... just try most of them out ... u will find that different cars will react differently to the petrol depending on the way its tuned ... i've tried lots of petrol in my car ... just about all i can think of .. even normal unleaded for half a tank to see how i went ... needless to say ... not good in terms of mileage and power ... the best for me is regular pulp .. bp that is ... probably the cleanest is bp out of all the brands from what i know ... low sulfer or whatever their advertising is ... but yeah i use that cause its 5cents cheaper and gives me more economy ... beats me why?? hehe .. i want to know how these engines will react to all this ethanol the government is trying to support for the poor sugar growing farmers ...
Prediction:Federal Government legislates that all regular fuel must have a small % of ethanol. Premium Fuels exempt , HOWEVER a new levy (read TAX) to be introduced to "offset negative revenue stream". (Because they know there will be little effective opposition. The fuel companies will go along with it and the media couldn't give a stuff)
[/cynicism]....:D
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
