I am not sure about Ethanol. Some say that it is actually good for the car (small amounts) and some say that you don't need it and can be harmful to engine.
Does BP have ethanol in their petrol? I know Shell advertise that it doesn't contain any ethanol.
Way back before the dawn of time (I.E. Before SAU started and we were all in SDU) someone took the inititive to test all 3 fuels and in terms of the RON ratings they were all pretty close with no major winner between the 3 of them. BP was first, then Mobil 8000 then Optimax. All over the 98 RON mark.
What was more interesting was the chemical content within the fuels. I can't remember what contained what but Optimax had other additives and stuff. I think it was supposed to be a bad thing but don't quote me on that.
I've since tried to find the thread but it's gone to Thread Heaven... :P
However I feel that you should stick with what you think. All 3 aren't bad and it's not like your going to gain massive HP by running [insert fuel brand here]. People have had different experiences with all fuels some run better on this, others on that.
I use whatever I'm closest to when I need to fill up, but generally have gone for Optimax. Ive found through the 3 main ones that Ultimate seems to give me good fuel economy, where Mobil gives me good performance and Optimax is a combination. Like a good all-rounder... I have noticed that results on Optimax tend to vary from servo to servo sometimes, but if you find a good one stick with it.
Man BP Ultimate is pretty hard to find in my area!!
Drove into 2 BPs and one had premium unleaded and the other just had unleaded. Look like a fool driving in and driving off haha. I think I found one for sure now with BP Ultimate, but still haven't try it out yet.
i tryed bp and vortex and my car didnt like em at all
ive been told by many that these are the best and have highest octane etc
but for sum reason my line didnt take to it very well
ran much better with optimax
:confused:
I manage a caltex servo on the Gold Coast and it has the worst premium grade fuel I have used :D I never use Caltex Vortex it doesnt have the RON of the other brands... You can tell by the difference in price between the unleaded. Vortex is generally 5 cents dearer than unleaded at Caltex, BP ultimate is generally 8-10 cents dearer !!! I only run ultimate where possible, If I cant I use Optimax.... These two give better mileage which offset the extra cost.. Never really liked Mobile after all the deal with the aviation fuel getting diluted in our petrol so I havnt tried them! The other good thing to do is run Nulon petrol treatment.. by far the best. Its a red container.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
