My engine needs to come out of the GTR and I have a mate who is a mechanic who will do it for me, but has never pulled an RB engine out of a skyline before or any Japanese performance car. His main thing is 4WD's eg. Toyota patrols, hilux's etc. So asked me to try find out if there is anything special that needs to be known before he gets started. I am helping him of course but I will have limited duties due to knowing and doing very little mechanics in my time. Is it too big a task for the inexperienced?? etc your input would be much appreciated before getting stuck into it.
https://www.sau.com.au/forums/topic/211491-pulling-rb26-out-of-car/
There not too bad to take out. Some things to be aware of
1. Starter motor can be a bitch - either get it from the top with an extension bar with a uni joint oir a short stubby spanner from underneath (thats if the bolt ain't too tight)
2. Remove both drive shafts from the front diff. The drivers side one just pops out, bit of a prick gettin a lever bar in there, the passenger one just unbolts (6 bolts i think)
3. Remove wiring harness complete
4. The gear box can stay in there. It balances pretty well because of the rear transfer case. No need to support it really
5. Theres one heater hose thats a bitch underneath the plenum, undo it once you have the engine half way out
That's all i can remember really, i did it in my backyard in about 3 hrs. Make sure you drain the engine, coolant and front diff fluids otherwise it can get a bit messy
The first thing you do is take the bonnet off completely. You can see alot better, gives you alot more room to move
Enjoy :)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
