Hey guys,
Last night I was driving home minding my own business, doing less than 60 in a 60 zone and out of nowhere a cop car comes screaming up behind me with all lights flashing, anyway they pulled me over and checked my license and asked me to pop the hood. They were checking my car for a good couple of minutes, I guess trying to find anything obvious to nail me with...
Anyway, I had to admit that I had a BOV and they said the EPA would be in contact with me soon for an inspection.
Fair enough, I believe there are some laws as to emmissions from having BOVs which I was totally unaware of - so what are my options, besides a huge inconvenience, I'm working a lot and I need my car to get to work and home...
How long do these inspections take? Days? Does it cost me something?
What can I do in place of the BOVs? What will this cost? I really do not have any idea. I bought this car thinking that all I would need to do is service it and replace some parts here and there and eventually do an engine rebuild, but not this.
Advise would be greatly appreciated. Thanks!
https://www.sau.com.au/forums/topic/211497-busted-for-bov/
as far as i know buddy u dont have to pay anythign for the EPA test, wen the summon u, u just take thwe car there they test ur emissions and ur done, depending on the car it could take anywhere from 5min to 40min. but from the sounds of things u dont have much to worry about.
as for other options for the BOV, either plump it back or hide the atmo BOV is a place where no one can find it.
https://www.sau.com.au/forums/topic/211497-busted-for-bov/#findComment-3739062
This was your main problem, you admitted something. NEVER admit on the side of the road anything, they have to prove it and if they are not smart enough to find it then they will normally move on to the next motorist. You never be a dick about it, but "Sorry Officer I have no idea what a bov is" is a reasonable answer and in my case somewhat true.
Like your insurance company says, never admit to anything. If it is serious and you need to plea bargain later that is some ammo for you. On the other hand if you don't admit most/all modifications to your insurance company you may have no insurance if you need it.
https://www.sau.com.au/forums/topic/211497-busted-for-bov/#findComment-3739238
Nice bit of advise.. .Just what I was thinking after I said it.. oops! Will know better next time. I know not to be a smart ass to cops, there is no point, it just gets you in to extra trouble.
https://www.sau.com.au/forums/topic/211497-busted-for-bov/#findComment-3739276
epa test cost about 35 dollers unless it gone up over the years.
EPA and Exhaust noise inspections are different.
Exhaust noise tests at the approved testers costs money.
EPA full test at the EPA Testing station is free and always has been
https://www.sau.com.au/forums/topic/211497-busted-for-bov/#findComment-3744063
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
