hi guys when my car is ideling and u rev it to about 4 to 5000rpm it blows a small amount off white smoke i have no cat 3.7inch hks system it sort of builds up water inside like swet is this a problem and i wasnt reving it to show of i was checking the oil pressure
is it normal two get funny fumes out the back if cat is removed
also i got busted and i will be reciving a epa notice do they care bout wheels and horn and shit all i was done for was a pod+cooler is dat all they will check cheers
Edited by CRMIN-4
https://www.sau.com.au/forums/topic/211524-white-smoke-when-reved-and-epa/
hi guys when my car is ideling and u rev it to about 4 to 5000rpm it blows a small amount off white smoke i have know cat 3.7inch hks system it sort of builds up water inside like swet is this a problemand i wasnt reving it to show of i was checking the oil pressure
G'day mate, I had a similar issue a little while back with a odd smell to exhaust and white puff. After much asking around and checks the problem revealed itself as a blown headgasket. It was bizarre, like a hairline crack in the seal ring that was letting water into bore. The indicator to this was having to refill radiator overflow bottle every two weeks or so. I hope this isn't the case for you, but may help you to solving your problem
  • 4 weeks later...
They will get you to put a cat converter back on and to be safe, put your stock exhaust back on at the same time. Even still if your stock exhaust is too loud they get you to put a resinator in. Noise level has to be below 90 decibels (90' model cars and before)
They will check your O2 Sensor to see if the car is running too rich or lean. They want it perfect.
BOV (Noise), Oil catch can = EPA will say WTF is that? (They probley have no idea what it is but they will not like it), high mount turbos = forcing more air = more emissions bla bla bla...
Air pods you can get away with
Intercooler I had no problems with
how are high mounts forcing more air exactly? how can they dispute that?
fwiw, i had my 32 over the pits in qld recently and they had me 'reinforce' the hole i cut for the intercooler piping. noone knew exactly what reinforcing was though, and let me tell you i saw ever mechanic and panel beater around here. its only the splash guard i cut for the normal intercooler kits, and everyone i saw said it was a joke for something non-structural.
it really gets on my nerves the things they come up with.
