Does removing the hicas on a gts4 affect the 4wd system at all?
I was about to install my lockbar when I was given some information from a mechanic that it may interfere with the 4wd operation. Something on the lines of; the hicas operation being taken into account when calculating the amount of torque to transfer.
I thought the only method for this was comparing the front to rear sensors.
Anyone know the dealio?
https://www.sau.com.au/forums/topic/211531-gts4-hicas-removal/
Hicas removal won't kill your 4wd unless you do things like removing wheel speed transducers / wiring / etc.
What you may end up with if it isn't done correctly is quite heavy power steering effort.
Search for info on gtr's removal process and problems that occur as the gts4 and gtr are the same.
100's on here have removed their's, non have affected ATESSA that I’ve read about.
Some have heavy steering.
- SydneyKid says that a small change of castor (?) offsets the heavier steering.
- Someone on here modified the PS rack solenoid with a solid flange, to make it permanently light.
- The Tomei kit has a box you splice in, (along with the locking shims) that stops the dash HICAS light from turning on, plus giving factory like PS assist control.
I slapped a lock bar on, removed everything but have yet to drive it. I want to keep proper PS assist on my modern (modern'ish lol) import, so I figure I'll just splice the Tomei black box in if its an issue ($100)
My cents
I'd place bets that the tomei box is just a load simulator so that the hicas module doesn't see the difference. If I wanted to rip mine out, which is a long way down my list of priorities first of which is getting it moving again, I think it would be quite easy to replicate.
You can also wire the soenoid to a constant 12v, as long as it doesn't burn out it will give you permanent light steering, probably not what you want at 100+ though. Easier to build a pwm solenoid controller with a dial on it so that you can adjust steering weight for your wants.
I've only experienced the heavy steering problem when the
car had HICAS ECU problems.
From what I understand you can bypass the HICAS solenoid
in engine bay that sends fluid to the rear of car. This
supposedly bypasses the part that can cause the steering
to go heavy.
Also from what I remember there is a tutorial on SAU forums
about how to bypass the HICAS solenoid in the engine bay.
Edited by SKYPER
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
