Selling some stock engine parts left over from a build.
Stock Pistons
Stock Conrods
Stock Plenum
Stock Injectors
Stock Camshafts
Stock exhaust manifold
Series 2 coilpacks
Open to offers :D
Contact by PM.
https://www.sau.com.au/forums/topic/211596-rb-25det-engine-parts/
how much for the coil packs and they come with a harness what cond e.g how many Km's can i get pic's
Coilpacks do not come with a harness.They had no sign of break down when they were in the car,which was only the other day.
They have 70,000kms on them but are in great condition.
Price is $125 delivered.
Pistons look to be in good nick.No scrathes or grooves.Even the rings look good.Would need a good clean ofcoarse.
I would let them go for $200+post o.n.o
if u know were i could get a harness as i am going form series one loom and ecu to series 2 i will take them
  • 1 month later...
