Hi Guys, My Name is Yury and I own a 1990 Skyline GTR. I'm actually from Canada but I need all the help I can get diagnosing a problem....
Here's my problem....I seem to be getting oil in my coolant. I have flushed the system numerous times but the oil just seems to keep finding its way back in. When I check the dipstick, the oil level doesn't drop very much, in fact very little. I know one possibility could be the head gasket, but I was wondering if anyone could suggest somethign else. The oil is clean of coolant. Also, my oil seems to turn black fairly quickly, I was wondering if that is normal or not. I am using royal purple 5W40. Any suggestions would be greatly appreciated.
Thanks
https://www.sau.com.au/forums/topic/211657-please-help/
Try a Air Pressure Test when you do a coolent flush...
So after topping up all the coolent in the radiator, do the test then.
The pressure metre should stay and not move.
If the pressure goes down, there might be a little leak...
Might have to get the engine seals / heads checked to see any leakage. Thats all I can think of...
https://www.sau.com.au/forums/topic/211657-please-help/#findComment-3741088
It would be the head gasket mate. I've never heard of anything else causing coolant and oil to mix. Try driving up a steep hill. If your car is over heating when you get to the top it has been confirmed. Also, try and get hold of a CO2 sensor tool. That should tell you whether you have a head gasket leak or not. Otherwise take it to a mechanic. I wouldnt drive it too much though, its not too good for the engine
https://www.sau.com.au/forums/topic/211657-please-help/#findComment-3741629
A leakdown test of the cooling system and/or block/head will tell you exactly whats wrong, aswell as many other things
If your missing water then its being sucked into the engine or forced out through the o/flow. Look for white milky residue under your oil filler cap, or excess moisture from the tailpipe on initial startup, bubbles in the coolant etc.
The alloy head can crack pretty easily also
https://www.sau.com.au/forums/topic/211657-please-help/#findComment-3743924
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
