Best Looking R34 Gt-r
With the black Nur spec at the top of this page, do the extra items on the display screen only come with the nur? Can the extra data be put on a normal 34 gtr?
the standard bnr34s dont have the extras unlike the Vspec2 and the NURs ect ect.
if you want em u gotta buy the NISMO ver 2 MFD (~$900)
http://www.nengun.com/nismo/multi-fuction-display-version-ii
  • Replies 210
My vspec has the same readings in that pic shown, however I bought the nismo mfd for the g force meter and lap timers as linked above. Cars in workshop atm so will be good to see it in action
correct me if im wrong but dosnt the G force sensor come with all bnr34s?
its only the inlet, exhaust temp, lap timer and a new boost sensor to read up to 3bar that are in the nismo units?
The sensor exists but there is no readout on the MFD on any GT-R except those with the Nismo MFD.
  • 1 month later...
^^ Nice GTR32X Z-Tune bonnet tops it off.
The TE37s you got looks great. Bit of a deep lip, LOL!
Are the rims 18" or 19"?
Only 19" can you get a lip like that on TE37's but the spokes are not as concaved like the 18's are.
yes they are the 19x10.5 all round.
I honestly prefer the look of the 19 over the 18s
thats my personal opinion
Yeah nice!
Cause I got 17" TE37 I do notice that its more concaved where as yours look stretched out with more lip. Deep lip FTW!
Same colour too, White. Hehe!!
pics of my car now with z-tune bonnet
car was not clean
Car looking very nice mate :D
Got some 19 x 10.5 LMGT4's coming myself - what size tyres are you running on the TE37's?
Any problems scrubbing etc? Is yours lowered from standard height?
Was hoping to fit 285/30/19's without too many issues
Car looking very nice mate :sick:
Thanks mate.
Tyres are 275/30/19 all round
I was adviced not to fit the 285 as they scrub.
My car does scrub sometimes on full lock not all the time though.
It has been lowered about 1.5-2inches all round
The lowered rear wing the black one above looks funny but not bad and the front badge looks worst than original. Whyd he/she change it :D
The 19" TE37's look like the nismo rims on the M-Spec on the first page.
Black on Black Gloss TE37's will never get boring.
I believe thats an original GT-R badge.
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
