Best Looking R34 Gt-r
With the black Nur spec at the top of this page, do the extra items on the display screen only come with the nur? Can the extra data be put on a normal 34 gtr?
the standard bnr34s dont have the extras unlike the Vspec2 and the NURs ect ect.
if you want em u gotta buy the NISMO ver 2 MFD (~$900)
http://www.nengun.com/nismo/multi-fuction-display-version-ii
  • Replies 210
My vspec has the same readings in that pic shown, however I bought the nismo mfd for the g force meter and lap timers as linked above. Cars in workshop atm so will be good to see it in action
correct me if im wrong but dosnt the G force sensor come with all bnr34s?
its only the inlet, exhaust temp, lap timer and a new boost sensor to read up to 3bar that are in the nismo units?
The sensor exists but there is no readout on the MFD on any GT-R except those with the Nismo MFD.
  • 1 month later...
^^ Nice GTR32X Z-Tune bonnet tops it off.
The TE37s you got looks great. Bit of a deep lip, LOL!
Are the rims 18" or 19"?
Only 19" can you get a lip like that on TE37's but the spokes are not as concaved like the 18's are.
yes they are the 19x10.5 all round.
I honestly prefer the look of the 19 over the 18s
thats my personal opinion
Yeah nice!
Cause I got 17" TE37 I do notice that its more concaved where as yours look stretched out with more lip. Deep lip FTW!
Same colour too, White. Hehe!!
pics of my car now with z-tune bonnet
car was not clean
Car looking very nice mate :D
Got some 19 x 10.5 LMGT4's coming myself - what size tyres are you running on the TE37's?
Any problems scrubbing etc? Is yours lowered from standard height?
Was hoping to fit 285/30/19's without too many issues
Car looking very nice mate :sick:
Thanks mate.
Tyres are 275/30/19 all round
I was adviced not to fit the 285 as they scrub.
My car does scrub sometimes on full lock not all the time though.
It has been lowered about 1.5-2inches all round
The lowered rear wing the black one above looks funny but not bad and the front badge looks worst than original. Whyd he/she change it :D
The 19" TE37's look like the nismo rims on the M-Spec on the first page.
Black on Black Gloss TE37's will never get boring.
I believe thats an original GT-R badge.
 Share
    • That is typical (for a rb at least) with a medium to large turbo, noting the format of the graph is probably misleading what you see a little (half portrait width but full height, in landscape it would look quite different) Basically until it hits target boost the torque curve is rising steeply, when that is 4000+ rpm it is not great to drive since almost all of your life is between 1,000 and 3,000 rpm. Once you hit target boost the wastegate opens and torque stops rising so quickly. From there the shape of the curve depends mostly on the cams and where they have a peak vs the rev limiter
    • Last of the maintenance items for now....not sure why but the drivers side window switch had heaps of wear on the right front and right rear switches Unfortunately, unlike earlier Skylines the controls are bolted to the door trim from the inside. So....off the with door trim. There are bolts or screws: Behind the door handle cover, pop it off from the handle side Under the rubber trim at the bottom of the door pull (also just pops up) Behind the courtesy light at the bottom. Other than that, just window down then pop off the usual selection of push in clips around the perimeter and the trim lifts up Interesting that they have a bolt on cover instead of the old school plastic held on by goop....I guess they prioritised sound levels over price Then, 2 screws and 2 plugs to replace the switch (looks identical to the Fuga/Q70 one incidentally) and put it all back together. Also much better
    • ok I understand, but the majority of turbo vehicles lose torque, or have a flat torque curve after the spool.  hence my initial misunderstanding. I didn't think this type of curve was possible
    • It is completely normal. Your original understanding is what was wrong, not what you see in the charts.
    • made with turbo and tuned by (hypergear)
