  • Replies 210
I was totally put off the Bayside Blue R34s by this. But time heals and I ended up getting one.
It made a big impression on me though and I have shown my teenage sons these pictures. I know how easy it would be for them to "borrow" my car.
Sorry to de-rail the thread. If people don't want to see this, then moderators please remove.
RIP.
Article from the Daily Telegraph attached.
Fatal_EVLR34_He_wasn_t_allowed_to_drive_it.htm
Edited by MLCrisis
Looks like Sebastien Loeb driving! :P Haha.
It was!!! I was showing him how to drive a GTR lol.... :P !!!
That "Nitto" v-spec II nur in spark silver is currently for sale on gtr.co.uk for 66k [pounds]!! what a car!!! The cars for sale on that forum are unbelievable. and the timeattack part of the forum is a good read, they take it pretty seriously over there!! the money they must put into these cars is nothing short of amazing...
Edited by Duncan1
Hey peeps...was going thru the thread..thot id put up something from my own collection.
But i'm all thumbs up for the Z-TUNE!!
Weighs only 1100kg, converted to Rwd, giving >600bhp. power to weight ratio is crazy!! By AMUSE - CarbonR R34 gtr..aarrrrr! Everything is Carbon..and anything that could be..was swapped with titanium metal to save weight.
They went all that effort to reduce weight, and then decide to use GT-C's..
Its not like GTCs weigh the earth either. When I picked up the box with one of my 19s in it, it felt like I was picking up not much more than the box
No they dont weigh a ton, but in comparison to say, RE30's, it's a world of difference when you're also talking about unsprung weight.
this is mine, got it few months ago from japan. goin thru some changes. still a little unfinished, few things left to go!
main thing i changed - wheels. new wheels r 20x10.5 -5 rear and 0 front. some ppl like some ppl dont, meh. i like it so fcuck em.
little did i know that the wheels wouldnt clear my 370mm front brakes! that issue will be fixed next few weeks i hope, then i can lower the car a bit and camber the wheels a bit :)
still to go - carbon boot fitted and nismo z tune guards, not too sure wat to do for a wing??? that do luck one looks off tap
had the engine bay tidied up, will have pics next week of it
before-
progress-
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
