hey all,
HICAS PROBLEM
got a little problem with my 92 model 32 gtr, ever since i have replaced my cluster with a nismo cluster ive been having a problem thats got to the top of my head, my hicas light just comes up and does not disappear, as soon as i take my car out the first turn i get to my hicas light just comes up and its doing my head in, ANY HELP WILL BE APPRECIATED GUYS,
4WD LIGHT PROBLEM AND ALSO SIMILAR TO A CONTINUOUS FUEL PUMP NOISE
also my cousin has a 89 r32 gtr and he just got his car back yesterday and he noticed that when he was driving his gtr the 4WD light was on continuous and will not disappear, and also when he turns his ignition on his got like some fuel pump noise that is constantly on even while driving, please guys can yous please help us,
THANK YOU VERY MUCH GUYS,
CHEERS
https://www.sau.com.au/forums/topic/211683-hicas-light-problem/
k i know this sounds obvious but did u check your fluid level?
and my motor swap i did in my car sets mine off when the hicas is supposed to kick in,even when the p.s fluid is fulll
yer my fluid levels seem to be fine i cant think of anything else
so if you remove the steering wheel does it really affct the hicas? i got that problem at the moment but my hicas comes on afetr like half hour, realy shits me, im at the stage where i have to get it removed,
and no he didnt remove his steering wheel when he changed his cluster because i was there in front of him but his steering wheels was not straight so we took it to a mates workshop and we fixed it there, it was ok for a while but just came back, gdzlar1 is my 1st cousin and im the one that has the 4WD light that stays on continuously while driving and when ever i turn the ignition on i have like this noise from where my diff is and its like a fuel pump noise that just stays on while driving and it doesnt stop until i turn the car off,
what might be the problem yous all think?
Edited by GTRBOS
HICAS - Did you check the fuse in the fuse box / Power steering fluid?
ATTESSA - You can check the sensors, I think, from memory is in the centre under the small compartment going towards the rear seats..?
<br />There are too many threads regarding the effect of the alignment of the sensor under the steering wheel affecting the operation of HICAS.<br />
<br /><br /><br />
ok if i was to cheak y wiring how would i do that and if its not the problem where is the hicas fuse located or the atessa sensor?
hey i got a 32 gts4 and my lhicas light never turned off until today when i had my 100,000km service.i got the power steering fluid flushed/bled and got new power steering fluid in it. Now i have no hicas light on yay
yer i think im going to do that aswell man, i was thinking of flushing my pwer steering fluid, will do asap mate
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
