Hi ACT gang,
After the defect on Friday night from exhaust reading 95db, (i really have to check the ADR's on this... The guy measured it 4100rpm, i thought for a 6cyl after 1996 it was on 3600rpm), I'll be needing to get my FMIC and POD engineered. Now I want to get my wheels engineered as well, but I don't think I will be able to because the max on the tyre placard says 7.5/8.5" and i'm running 8/9", plus the rear tyres have a load rating of less than 91V (88W or 89W i think, they are the Federal 595's in 265/35/18).
First question I have is:
Can someone confirm that these are the correct details for Ray Spence;
Ray Spence
Canberra Motor Works
38 Hoskins St Mitchell 2911
(02) 6241 8777
Second question I have is:
Does anyone have some wheels with legal rubber on them that I can borrow next week (if i can get the car booked into Dickson)? Or does anyone know someone selling some cheap rims to put tyres on that will fit the 33?
Thanks in advance all
Cheers
Sam
https://www.sau.com.au/forums/topic/211690-defect-questions/
Hey mate, i know your pain to well. I have federal 595's on my car, went through dickson 2weeks ago and they where fine. They where engineerred ofcourse but they did make it through dickson.I had r17 40/255's on. Just get them engineered when you get the other things engineered, but make sure the engineer engineers a set of stock wheeels aswell, otherwise u cant put stock wheels on your car ever again.
Cheers for the replies guys,
I have the car booked in with Ray Spence this Thursday, and some standard rims coming down tomoz from Sydney.
I also realised that it is my front wheels that are the incorrect load rating for the car (88W 225/40/18). Federal didn't have 235s in stock at the time I put the rims on...
r33skyflyin, i can't see why you cannot put stock wheels on my car ever again once my other rims are engineered..................
Ok, so I've just left Dickson rego inspection. Failed. Not happy.
They failed me on the exhaust being 4mm too low (96mm), so right now I have the car at Powatone (awesome guys out there) getting the flanges rotated and the middle muffler raised up as far as it can (there isn't much room, but I am praying for a miracle). And then i'm heading straight back to Dickson to get the green tick on the car.
If that's all they picked then well done. It is a pain having to spend $$$$ for the sake of 4mm but not clearing the 100mm block is money for jam for these guys. When they start picking BS items is when it really starts to p u off.
Why would you need an engineers cert for a FMIC? As long as it's not hang out everywhere, shouldn't be a drama, it's just a larger repositioned OEM part.
Pod filters(AFM) need to be secured and the pod should be boxed for noise reasons to avoid defect.
Did you change your exhaust and did they actually test your dB at Dickson?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
