I have just discovered i have coolant leaking from under my dash around the heater area. Does this mean my heater core is busted and i need go through the dash removal process that i have read in other threads.
Is there an easy fix or an alternative to all of this?
https://www.sau.com.au/forums/topic/211725-leaking-coolant-under-dash/
ive read somewhere that it can be done by removing the AC unit and not the whole dash, requiring an AC regas, maybe someone can confirm this. You definitely need a new core. i bought mine from here when I did my R33, check compatability though with Stageas.
http://www.ttzed.com/products/products_det...g&do=detail
that was a whole dash job
there are people who have removed the core on a R33 Skyline (auto only from what I understand) via the glovebox; seems only half the dash gets pulled out.
Ive had 2 quotes to do mine, both around $500 in labour plus new core
might be a cold winter for me =(
Mine had the core replaced just before I bought it, and if you go and ask Regan nicely, he may show you the photo's :)
But, at the end of the day, I have heard a lot about people saying it can be done with half the dash removed, but I have never seen it done. Just suck it up and rip the dash out Morgan. There is nothing technical about it, but it is a fairly long and arduous task :yes:
Dale - I was hoping to just pull out half the dash - the pics of the full dash removal are scary! But from the look of it i will give it a go myself in a couple of weeks.
I just have bad memorys of pulling part of the dash out of my XR6 falcon and putting it back to find a few dash lights not working so repeating the process three times!!
Why cant the heater break in the middle of summer rather than the beginning of the cold.
had the same problem few months back its due to jap land not using alot of antifreeze so the heater core falls to pieces. I ordered a new one and got it fitted without a dash out job just removed the glove box and the ac matrix then got the heater matrix out from behined the radio. took about 3hrs. still need to empty an re gas the ac tho!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
