  • Replies 69
should be able to figure it out. Just do a search in here for the right thread (should be in the first three pages atually) and see what the minimum offset is. As loong as it doesnt sit in so much that it will fol on ur suspensin, then yes it will fit. THen its just a matter of having it hang out your guard.
depends on what your definition of "fitting" is...
will it sit within the guards, so that it is legal in Australia, no way in hell... my 17x9 +38 is close to flush, so a rim that sits 58mm further out would need about a 50mm flare to make it legal.
not in australia
dont care
and your full of shit
i got VIP friends in australia with the same fitment. never had a problem
unless you bothered to look, this is skylines AUSTRALIA
also, i never mentioned you would have problems, all i said was that it will not sit within stock guards, you would need a flare to LEGALLY conceal the wheel...
why don't you go play with you "VIP friends" seeing as nobody seemed to miss you when you were gone.
becuase it looks like im the only person pushing the boundaries of a stagea.
well me and like 2 or 3 others on here that i stay in touch with.
do me a favour and point me to an english stagea forum.....not in australia
...thanks
Good work Grant look`s good what`s the go with the guard`s dude have you had them rolled ??or are they stock ?,they don`t look stock do they hit any wear ???,what suspension set up are you running.Good to see your still got some work to do on the stagea,need some more photo`s of front wheel fitment ????,cheer`s grant keep up the good work,cheer`s chuckie
lotsa rolling
lotsa hammering the inner fender liner
lotsa pulling
lotsa sweat
wheel is like 3/4 of an inch from hitting hte shock
runnign 18k/16k custom setup
cusco sway bars
dmax adjustable arms all around.
way fun.
Good work You need to get some PHOTO`S so we can see what work you have done,gives us some idea`s on what`s what,& what can be fitted ,What rim`s are going on the Front ??,cheer`s chuckie,
nah
with a proper shock matching, its a decent ride
i mean, its stiff
but no worse than liek 10k 8k on an s chassis
its all in the total suspension tuning, not JUST spring rates.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
