  • Replies 69
I'll say having the wheels cambered in to sit under the guards does look hot, but it's a bit of a waste having such a wide rim cambered up (lose alot of traction). I'd prefer to see those wheels with less camber and a bit of guard work to match.
Edited by daisu
again - CEDRIC PICS
And thats a tight lookin stagea grant. Not runnin an exhaust?
its a custom exhaust i made on the stag
R32 Downpipe cut and reworked
then an axle dump exhaust with a blitz mid muffler
pu tit this way
my cedric wore through SIDEWALLS
not tires.
literally
a set every two or 3 months
thanks Grant the xd9s look hot, definately suit the car in silver too (mines silver too) and fitment actually looks good and not too extreme :) Could u take a pic of your rear gaurds close up from the side to see the flaring work?
i will tomorrow
its dark outside now
that looks tough... so much camber it looks broken, which im not a fan of, but a tough looking car. Wow i hope it is sitting on airbag suspension? Safe to drive it in the snow like that? Do they run the 4.5L V8?
i run a VQ30DET with some mods bringing to an actual 300PS dyno number
yeah it has a custom S13 suspension swap with coilovers and airbags on the coilovers
but i actually drive lower than that daily
safe is a relative word in the VIP world
haha wow i really hope your joking... but then again there are a lot of tyres in the background of your stagea pics!!!!
thats why i haev so many
most of those are 225/40/18s
only liek 4 arent.
i have 8 more in another location
lol
funny story (kinda long i guess)
I was at a stoplight where some cops were talking
they kept looking at my car and pointing. SO everytime they looked away i would hit the switch, and lower the car a little. This went on for like 6 or 7 times until the light turned green and they were looking at me. I hit the up switch and they literally jumped with huge eyes lol. It was soooooooo funny i was laughing for like a day
Nice fitment on the Stagea, what wheels are they?
I was running 10 +20 rear and 9.5 +1 fronts on my Stagea. To me it wasn't extreme fitment, but for Australian standards it was a fair bit extreme.
Would have lowered it more but the suspension did not allow me, plus the rear sometimes sagged during towing so the height that I had was idea. I left the front gaurds untouched, and the rears just got a lip. Didn't want to flare incase I put thinner/higher offset wheels when selling, but the guy bought it with the wheels.
Here are two photos of my previous two cars.
My first car:
My second car:
I want to buy another Stagea in future and VIP the shit out of it. Stagea + VIP = WIN
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
