well i can tell you just a clean out has to improve flow over the rough arsed factory job
Second attempt was done today 16 straight hours worth muttering dont f#$@ this one up, so off to have new valve guides inserted tomorrow.
""""""love that cutaway pic.
there was some interesting info in last issue of race magazine about taking an internal cast of the port to see how smooth the shape is""""""
Exactly..!!, thats the way to get identical-ish ports.
Aaaaanyway Tacker, ya had the nuts to have a go, sometimes it goes wrong, but good one mate all the same, I been there too.
Cool idea the cut-away, nice one.
Very nice pics, and bummer to see it went wrong first time - gotta gut you.
I was sure I've heard that unless you're going mental with it, theres no point doing any more than maybe a basic tidy up of the ports - no reprofiling or anything as they're so good stock. I know not everything you hear is true, but sure that I've heard that its not uncommon for RH9 cars to not have had any work done to the ports on the cars - just big cams and whatever is needed to fit them and actuate the valves correctly.
not quite true there is a lot to do just to clean up the rough factory job, i found steps in the intake port just under the valve seat of over 1mm in depth.
Then it goes into inner radius for the intake and outer radius for the exhaust etc. There is quite a bit you can do on the intake to reprofile and enlarge the exhaust ports.
but if what has been done this time gives me a10 to 15% increase in flow i will be well chuffed.
pics tonight of finished head
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
