Hey guys,
Looking at purchasing a FMIC, dont mind spending money thats needed, wanna do things once and right!
My question is what are your opinions on direct bolt on intercoolers and cutting into your chasis? bad idea to be cutting into chasis for shorter piping or is it fairly safe? i was looking at these couple intercoolers just curious to know which would be the better way to go? Any input would be great.
Thanks
https://www.sau.com.au/forums/topic/211818-intercooler-choice/
find a workshop that will supply and fit an intercooler for around $500
there should be a few workshops these days that can do them at this price
this should also include not cutting front reo bars etc and a proper install
ask them before you hand over $
The first one is less work, but if you ever plan on running a forward facing plenum you wont be able to keep it.
Tube and fin intercoolers are more efficient, and usually dearer. APEXi used to make a Hybrid Intercooler which was both Bar and Tube...
The only thing with the first intercooler is that the piping is for a Supra?
The pipes come out on the one side like the Blitz, but they are facing the wrong way [should be facing away].
I run with a Blitz, no complaints.
I've just had a HDI one installed thinking of changing it to a Justjap one so I can run the standard airbox again ... very happy with their exhaust system so I'm sure I'll be happy with this also ... although I'm only gonna run 10-13psi max through it it probally overkill
I just had a jap intercooler installed by Morpowa in Adelaide, trust me.. keep away from the cheap alternative. The cooler is cheap (around $350 for kit inc piping) and the quality seems to be very good, but the piping is completely wrong (sold as an R33 R34 kit). The installers swore black n blue that they would never fit one again. Pipes too short, silicon sleeves too small, had to change the wiper motor to a smaller one to fit, spacers from the block so piping could be secured.. all kinds of hassles. Just get the Greddy kit.. so much easier and no hassles!
Has anyone installed one of those just jap ones that use the standard piping on an r33?
Post up pics how it looks from the front! :):D:D
Give me a couple of weeks and I will show pics. Making payment tomorrow morning for mine, so by the time it gets here will be early next week most likely, install when I get the chance after work/the next weekend. Though mine will be painted black with black joiners, aim is stealth.
Hmmm was considering JustJap kit, now my confidence is a little bit tattered. :ninja: So the problem was with the pipng and joins? Perhaps get a justjap intercooler and buy piping/joinery seperate?
Hmmm was considering JustJap kit, now my confidence is a little bit tattered. :D So the problem was with the pipng and joins? Perhaps get a justjap intercooler and buy piping/joinery seperate?
Absolutely.. only problem is.. it may end up being cheaper just to get the Greddy kit, i think i saw the whole kit with piping on ebay for around $500. Or just take it to the istaller and let em put on whatever they suggest, i think the hybrid or Greddy from performance shops are around the $1000 mark plus around $300 for install
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
