I was testing the volatge coming from my AFM on my r33 gtst s2 to see if its operating correctly by connecting a multi-meter to 2 of the 3 terminals, negative and positive. I incorrectly tried connecting it another way through the meter which caused the car to have a rough idle and then shutoff. Now it will not start at all. It cranks over and idles for a split second then shuts off. Ive checked all fuses that I know of and none are gone. Ive also reset the computer and this has achieved nothing. The care starts with the AFM disconnected but it has a rough idle. Any assistance would be greatly appreciated. Cheers.
Edited by thirtythree-II
Ouch :)
Sounds like you killed it. If it starts fine with no AFM (prolly in limp mode though) and not at all with it connected, you most likely have killed the AFM :(
Multimeter on the signal and ground wires should give you a reading (don't quote me on that lol) that reading is whats confusing the ECU, causing it to not start. Maybe its outputting 5v, and the ECU doesn't like it.
Maybe checking for error codes and testing with known good AFM gets my tick too.
The small voltages that are going on there (+5 volts) wont damage the loom wire.
A small arc when you were testing "could have though, damaged the AFM.
- I guess you could run 4 new test wires from ECU to AFM (just out the side of the bonnet, through the window) to test the loom.
- Borrow an AFM to test the AFM
I done a diagnostic test and it reported but no.12 afm problem.
I found power coming from the afm connector.
I will test the continuity of the afm signal sensor wire (no.27) and also the earth wire (no.26)
Are r33 s1 and s2 ECU identical with terminal pin connector layout????
there's continuity from both terminals no.26 & 27 to the AFM connector.
so it must be the AFM.... perhaps the AFM I tried form the wrecker was stuffed too.
I need to get my hands on a known working r33 s2 AFM.
tryed yet another AFM and car still didnt work.
It must be the ECU??????????
but why did the diagnostice test read no.12 afm errror.
is is the processor within the ECU for the AFM thats fried?????
anyone got a ECU for sale?
cheers for your help guys but 'buck' sorted me out.
i've got a happy 33 again.
I replaced the ecu and it started first thing.
what confuses me is that the diagnostic error code was no. 12 which is AFM error, but it was in fact the ECU????
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
